BT.com
Wishlist
iiyama 42" LCD/LFD Display 1920 x 1080 DVI-D HDMI VGA USB
Delivery
Standard Due date unavailable
With 1920x1080 Full HD resolution and Projective Capacitive 12 point touch technology, the ProLite TF4237MSC-B1AG delivers seamless and accurate touch response. Featuring an IPS Direct LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for Interactive Digital Signage. In addition to the superb image quality, the display comes with a rugged bezel making it suitable for demanding environments.
Iiyama ProLite TF4237MSC-B1AG 42" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
42"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
100 Watt
Power Consumption (On mode)
68 W
Energy Consumption per Year
99 kWh
97.55 cm x 8.8 cm x 57.5 cm
24 kg
Energy Class
Class B
100 Watt
68 W
99 kWh
Diagonal Class
42"
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, Face-up Mode
Dimensions
Without stand
97.55 cm
8.8 cm
57.5 cm
24 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
7H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
1000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.4833mm x 0.4833mm
Touchpoints Qty
12
Response Time
6 ms
Display Menu Language
English, German, French, Polish, Russian, Spanish, Dutch
Colour Temperature Control
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - built-in - 7 Watt
Connector Type
DVI-D input , VGA input , Audio line-in , Audio line-out , Serial input , Serial output , USB , Remote control
Clamper
VGA cable , DVI cable , USB cable
DDC-2B, VESA DPMS, TUV Bauart, IPX1
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Scroll to top
