BT.com
Wishlist
IBM Emulex Dual Port 10GbE SFP+ Embedded VFA III for IBM System
IBM Emulex Dual Port 10GbE SFP+...
£379.17
£379.17
Add to wishlist
Delivery
Standard Due date unavailable
The Emulex 10GbE Virtual Fabric Adapters III for IBM System x are members of IBM's comprehensive networking portfolio of 10 Gb Ethernet (10GbE) converged network adapters (CNAs). They deliver industry-leading performance and scalability per watt, reducing requirements for power and cooling. Storage protocol offloads enable the efficient use of computing resources and the support of more virtual machines per CPU, and reduce the number of servers required to support data center demands.
Emulex Dual Port 10GbE SFP+ Embedded Adapter for IBM System x - network adapter - 2 ports
Network adapter
Integrated
Interface (Bus) Type
Advanced Mezzanine Card (AMC)
1.7 cm x 16 cm x 6 cm
Ports Qty
2 ports
10 GigE
Data Transfer Rate
10 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.1Qbb, IEEE 802.1Qaz
SuSE Linux Enterprise Server, Microsoft Windows Server, VMware ESX Server, Red Hat Enterprise Linux Server
System x iDataPlex dx360 M4; System x3550 M4; x3650 M4
Network adapter - 2 ports
Integrated
Wired
10 GigE
Data Transfer Rate
10 Gbps
TCP/IP, UDP/IP
Fault tolerance, load balancing, VLAN support, IPv6 support, Jumbo Frames support, TCP Chimney Offload support, IPv4 support, teaming support, PXE support, Large Send Offload (LSO), adaptive load balancing (ALB)
2 x network - SFP+
Compatible Slots
1 x Advanced Mezzanine Card (AMC)
1.7 cm
16 cm
6 cm
55 °C
5 - 95% (non-condensing)
Lenovo System x iDataPlex dx360 M4 , Lenovo System x3550 M4 , Lenovo System x3650 M4
Scroll to top
