BT.com
Wishlist
HyperX Savage Red 8GB (2x4GB) DDR3 2400MHz CL11 DIMM Memory
HyperX Savage Red 8GB (2x4GB) DDR3...
£63.13
£63.13
Add to wishlist
Delivery
Standard Due date unavailable
Attack the competition with HyperX® Savage memory. Its unique, asymmetrical red heat spreader is made from high-quality aluminum and has a black PCB and a diamond cut finish to make your game shine and help you stand out in the crowd. The heat spreader dissipates heat so your system stays cool and reliable and its low profile fits under oversized CPU coolers. Built-in, hand-tuned XMP profiles mean that even noobs can overclock their platforms with simple adjustments in BIOS.
Eye-Catching Color and Asymmetrical Design
With its aggressive design HyperX Savage memory stands out from the crowd. Combine that with asymmetrical red heat spreader and black PCB which can look great with many systems.
Intel XMP Ready
HyperX Savage is available in frequency speeds from 1600MHz to 2400MHz. You can achieve the published speeds by simply selecting the built in Intel XMP profiles in BIOS.
Lifetime Warranty with Free Technical Support
When you spend that much time building your perfect system make sure your memory lasts. With HyperX memory you get a lifetime warranty and free technical support to help you out if you’re in a tight spot.
FEATURES
Fast — top-performing modules available with low-profile heat spreader
Unique — red, asymmetrical heat spreader sets new trends for PC builds
Quality — aluminum die-cast heat spreader with a diamond cut finish
Design — low profile to fit under oversized CPU coolers
Reliable — 100-percent factory tested
Guaranteed — lifetime warranty, free technical support
HyperX Savage - DDR3 - 8 GB: 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC3-19200)
Latency Timings
CL11 (11-13-14)
Single rank, eight banks, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, Black PCB, red heatspreader, low profile heatspreader, asymmetrical heatspreader, unbuffered
Voltage
1.65 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.29
Speed
Latency Timings
CL11 (11-13-14)
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.65 V
Lead Plating
Gold
Colour Category
Red
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great Ram
Reviewed by Robert on 02/12/2015
Great Ram, Super cheap for what you get, and looks great.
Got this to boost my Apu and got about 15 more fps in high demanding games, worth every penny.
5* High quality.
Reviewed by Mark on 01/03/2015
Win 7 loads fast. Maybe this is something to do with it as well.
Scroll to top
