BT.com
Wishlist
HyperX Savage Red 8GB (2x4GB) DDR3 2133MHz CL11 DIMM Memory
HyperX Savage Red 8GB (2x4GB) DDR3...
£72.15
More than 50 in stock
£72.15
Add to wishlist
Delivery
Standard 3-5 working days
Release your inner Savage and attack the competition with HyperX® Savage memory. Its unique, asymmetrical red heat spreader has a black PCB and a diamond-cut finish to make your game shine. The heat spreader dissipates heat so your system stays cool and reliable and its low profile fits under oversized CPU co olers. HyperX Savage is XMP Ready and comes in a range of speeds from 1600MHz to 2400MHz. Its trend-setting design puts you and your system ahead of the game.
HyperX Savage - DDR3 - 8 GB: 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC3-17000)
Latency Timings
CL11 (11-12-12)
Single rank, eight banks, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, Black PCB, red heat spreader, low profile heat spreader, asymmetrical heatspreader, unbuffered
Voltage
1.5 / 1.6 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.29
Speed
Latency Timings
CL11 (11-12-12)
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.5 / 1.6 V
Lead Plating
Gold
Colour Category
Red
HyperX Savage Red 8GB (2x4GB) DDR3 2133MHz CL11 DIMM...
£72.15
Save on this ideal PC Build kit!
Save £16.94
£97.53
Scroll to top
