BT.com
Wishlist
HyperX Savage Red 8GB (2x4GB) DDR3 1866MHz CL9 DIMM Memory
HyperX Savage Red 8GB (2x4GB) DDR3...
£63.81
£63.81
Add to wishlist
Delivery
Standard Due date unavailable
HyperX HX318C9SRK2/8 is a kit of two 512M x 64-bit (4GB) DDR3-1866 CL9 SDRAM (Synchronous DRAM) 1Rx8, memory module, based on eight 512M x 8-bit FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module has been tested to run at DDR3-1866 at a low latency timing of 9-10-11 at 1.5V. The SPDs are programmed to JEDEC standard latency DDR3-1600 timing of 11-11-11 at 1.5V. Each 240-pin DIMM uses gold contact fingers.
HyperX Savage - DDR3 - 8 GB: 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL9 (9-10-11)
Single rank, eight banks, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, Black PCB, red heatspreader, low profile heatspreader, asymmetrical heatspreader, unbuffered
Voltage
1.5 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.29
Speed
Latency Timings
CL9 (9-10-11)
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.5 V
Lead Plating
Gold
Colour Category
Red
HyperX Savage Red 8GB (2x4GB) DDR3 1866MHz CL9 DIMM...
£63.81
Save on this ideal PC Build kit!
Save £8.29
£82.98
Scroll to top
