BT.com
Wishlist
HyperX Savage Red 32GB (4x8GB) DDR3 2133MHz CL11 DIMM Memory
HyperX Savage Red 32GB (4x8GB) DDR3...
£273.21
£273.21
Add to wishlist
Delivery
Standard 1-3 working days
HyperX HX321C11SRK4/32 is a kit of four 1G x 64-bit (8GB) DDR3-2133 CL11 SDRAM (Synchronous DRAM) 2Rx8, memory module, based on sixteen 512M x 8-bit FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 32GB. Each module has been tested to run at DDR3-2133 at a low latency timing of 11-12-12 at 1.6V. The SPDs are programmed to JEDEC standard latency DDR3-1600 timing of 11-11-11 at 1.5V. Each 240-pin DIMM uses gold contact fingers.
HyperX Savage - DDR3 - 32 GB: 4 x 8 GB - DIMM 240-pin
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC3-17000)
Latency Timings
CL11 (11-12-12)
Dual rank, eight banks, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, Black PCB, quad channel, red heatspreader, low profile heatspreader, asymmetrical heatspreader, unbuffered
Voltage
1.5 / 1.6 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.29
Speed
Latency Timings
CL11 (11-12-12)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.5 / 1.6 V
Lead Plating
Gold
Colour Category
Red
HyperX Savage Red 32GB (4x8GB) DDR3 2133MHz CL11 DIMM...
£273.21
Save on this ideal PC Build kit!
Save £16.94
£298.59
Scroll to top
