BT.com
Wishlist
HyperX Kingston HyperX Savage DDR4 4GB DIMM 288-pin 2800 MHz/PC4-22400 CL14 1.35V unbuffered non-ECC
HyperX Kingston HyperX Savage DDR4...
£40.53
30 in stock
£40.53
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
HyperX Savage - DDR4 - 4 GB - DIMM 288-pin
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2800 MHz (PC4-22400)
Latency Timings
CL14 (14-16-16)
Single rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heat spreader, sixteen banks, asymmetrical heatspreader, unbuffered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.36
Speed
Latency Timings
CL14 (14-16-16)
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.35 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2666 MHz - 1.35 V - CL14 - 14-15-15 , Intel Extreme Memory Profiles (XMP) - 2800 MHz - 1.35 V - CL14 - 14-16-16
Colour Category
HyperX Kingston HyperX Savage DDR4 4GB DIMM 288-pin...
£40.53
Save on this ideal PC Build kit!
Save £10.36
£60.08
Scroll to top
