BT.com
Wishlist
HyperX Kingston 4GB 2400MHz DDR3 Non-ECC CL11 DIMM XMP HyperX Savage
HyperX Kingston 4GB 2400MHz DDR3...
£39.68
38 in stock
£39.68
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
HyperX Savage - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC3-19200)
Latency Timings
CL11 (11-13-14)
Single rank, eight banks, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, red heat spreader, low profile heat spreader, asymmetrical heatspreader, unbuffered
Voltage
1.65 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.29
Speed
Latency Timings
CL11 (11-13-14)
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.65 V
Lead Plating
Gold
Colour Category
Red
HyperX Kingston 4GB 2400MHz DDR3 Non-ECC CL11 DIMM XMP...
£39.68
Save on this ideal PC Build kit!
Save £10.36
£59.23
Scroll to top
