BT.com
Wishlist
HyperX Impact 8GB DDR3L 1866MHz CL11 SODIMM Memory
HyperX Impact 8GB DDR3L 1866MHz...
£54.85
30 in stock
£54.85
Add to wishlist
Delivery
Standard 3-5 working days
HyperX Impact memory boasts the world's fast SO-DIMM frequency - 2666 MHz - to keep you ahead of the curve and level up your game. It automatically recognizes the platform it's plugged into and auto overclocks to the high frequency published with no need to adjust system BIOS settings. So you get extreme performance that supports notebooks and other small form factor systems using either AMD or the Intel CPU technologies with no hassle at all - even if you're a newbie.
Kingston HyperX Impact Black Series - DDR3L - 8 GB - SO-DIMM 204-pin
RAM memory
8 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz ( PC3L-14900 )
Latency Timings
CL11 ( 11-11-11 )
Dual rank, eight banks, On-Die Termination (ODT), Low Voltage, Black PCB , unbuffered
Voltage
1.35 / 1.5 V
Limited lifetime warranty ( Russia - 10 years )
8 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11 ( 11-11-11 )
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.35 / 1.5 V
RAM Performance
SPD - 1333 MHz - 1.35 / 1.5 V - CL8 - 8-8-8 , SPD - 1600 MHz - 1.35 / 1.5 V - CL10 - 10-10-10 , SPD - 1866 MHz - 1.35 / 1.5 V - CL11 - 11-11-11
£54.85
Save on this ideal PC Build kit!
Save £9.25
£74.41
Scroll to top
