BT.com
Wishlist
Hypertec Hyperam 2GB PC2-5300 128X8 DIMM Memory Module
Delivery
Standard Due date unavailable
Hypertec provides PC enhancement solutions that enable you to get maximum performance and comfort from your IT equipment, with minimum fuss.
From Matched Memory and Storage to peripherals; DVD Duplication Units to Ergonomic Workstation Equipment, Laptop Luggage and Security Products, Hypertec provides a complete solution to your needs.
Hypertec has spent over 20 years as a leading figure in the IT industry and working with the top resellers, so you can have confidence that we know what we're doing.
Hyperam - DDR2 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
8K refresh, dual rank, eight banks, On-Die Termination (ODT), Serial Presence Detect (SPD), unbuffered
Voltage
1.8 V
Lead Plating
Gold
2 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Non-ECC
Module Configuration
256 x 64
Chips Organization
128 x 8
Voltage
1.8 V
Lead Plating
Gold
RoHS, Lead-Free
Scroll to top
