BT.com
Wishlist
Hypertec DDR3 - 8 GB - DIMM 240-pin
Hypertec DDR3 - 8 GB - DIMM...
£81.99
£81.99
Add to wishlist
Delivery
Standard Due date unavailable
Hypertec - DDR3 - 8 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - 1.35 V - registered - ECC - for Dell PowerEdge C8220, R320, T320; Precision T5500, T7500
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz ( PC3-10600 )
Dual rank, Low Voltage , registered
Voltage
1.35 V
DELL A6996808
Dell PowerEdge C1100, C2100, C6100, C6105, C6145, C6220, C8220, M420, M520, M610, M620, M710, M910, M915, R320, R415, R420, R510, R515, R520, R620, R715, R720, R810, R815, R820, R910, T320, T420, T620; PowerVault DL2200; Precision T5500, T7500; Precision Fixed Workstation R5500, T3600, T5600, T7600
8 GB
Upgrade Type
System specific
DELL A6996808
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Voltage
1.35 V
Dell PowerEdge C1100, C2100, C6100, C6105, C6145, C6220, C8220, C8220X, M420, M520, M610, M610x, M620, M710, M710HD, M910, M915, R320, R410, R415, R420, R510, R515, R520, R610, R620, R710, R715, R720, R720xd, R810, R815, R820, R910, T320, T410, T420, T610, T620, T710 , Dell PowerVault DL2200 , Dell Precision T5500, T7500 , Dell Precision Fixed Workstation R5500, T3600, T3600 Base, T3600 Essential, T5600, T5600 Advanced, T5600 Base, T5600 Essential, T7600, T7600 Advanced, T7600 Base, T7600 Essential
Scroll to top
