BT.com
Wishlist
Hypertec 8GB PC3-12800 Low Voltage DDR3 SODIMM Memory Module
Hypertec 8GB PC3-12800 Low Voltage...
£74.66
£74.66
Add to wishlist
Delivery
Standard Due date unavailable
Hypertec - DDR3L - 8 GB - SO-DIMM 204-pin - 1600 MHz / PC3L-12800 - 1.35 V - unbuffered - non-ECC - for HP 250 G5 (RRD3); EliteBook 745 G3, 755 G3, 840 G1; ProBook 430 G3 (RRD3), 440 G3 (RRD3), 45X G3 (RRD3), 470 G3 (RRD3)
RAM memory
8 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Low Voltage, unbuffered
Voltage
1.35 V
HP 693374-001
HP EliteBook 2760, 725 G2, 745 G2, 755 G2, 820 G1, 820 G2, 840 G1, 840 G2, 84XX, 850 G1, 850 G2, 85XX, 87XX; EliteBook Folio 1020 G1, 9470; EliteBook Revolve 810 G1; ProBook 430 G1, 450 G0, 45X G1, 45X G3, 470 G0, 470 G1, 64X G1, 65X G1; x360; ZBook 15, 15u G2, 17
8 GB
Upgrade Type
System specific
HP 693374-001
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Voltage
1.35 V
HP 250 G5 , HP EliteBook 2170p, 2560p, 2760p, 725 G2, 745 G2, 755 G2, 820 G1, 820 G2, 840 G1, 840 G2, 8460p, 8460w, 8470p, 8470w, 850 G1, 850 G2, 8560p, 8560w, 8570p, 8570w, 8760w, 8770w , HP EliteBook Folio 1020 G1, 9470m , HP EliteBook Revolve 810 G1 Tablet , HP Envy Pro , HP Mobile Thin Client 6360t , HP ProBook 430 G1, 430 G3, 440 G3, 450 G0, 450 G1, 450 G3, 455 G1, 455 G3, 470 G0, 470 G1, 470 G3, 6360b, 640 G1, 645 G1, 645 G2, 6460b, 6465b, 6470b, 6475b, 650 G1, 655 G1, 6560b, 6565b, 6570b , HP x360 310 G1 , HP ZBook 15 Mobile Workstation, 15u G2 Mobile Workstation, 17 Mobile Workstation
Hypertec 8GB PC3-12800 Low Voltage DDR3 SODIMM Memory...
£74.66
Save on this ideal PC Build kit!
Save £8.29
£93.83
Scroll to top
