BT.com
Wishlist
Hypertec 4GB SODIMM 204-pin DDR3 Memory Module
Delivery
Standard Due date unavailable
Hypertec - DDR3 - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered - non-ECC - for Toshiba Portégé Z930; Satellite C50, C55, C850, C855, C875, L75, P75, S55, S75; Tecra R950
RAM memory
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Unbuffered
Toshiba PA5037U-1M4G
Toshiba Portégé R930, R935, Z930; Qosmio X870; Satellite C50, C55, C70, C75, C850, C855, C870, C875, L50, L55, L75, L830, L850, L855, L870, L875, P75, P845, P855, P870, P875, S55, S75, S875, U840, U940, U940/K002, U945, Z930; Satellite Pro C850, C850/3005, L830, L850, L850/R001; Tecra R940, R950
4 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 204-pin
Toshiba Portégé R930-0C3, R930-0HL, R930-180, R930-18D, R930-1CL, R930-1K5, R930-1K7, R930-1K8, R930-1K9, R930-1KE, R930-1KT, R930-1KZ, R930-1L0, R930-1LQ, R930-1LV, R930-1MM, R930-1NV, R930-1NZ, R930-1P2, R930-1PP, R930-BT9300, R930-SP3178KM, R930-SP3256KL, R930-SP3258KL, R935-ST4N01, Z930-06M, Z930-08E, Z930-17T, Z930-188, Z930-18F, Z930-18P, Z930-18W, Z930-190, Z930-SP3254SL , Toshiba Qosmio X870-14W , Toshiba Satellite C50-AST2NX2, C50T-AST2NX2, C55-A5243, C55-A5243NR, C55-A5246, C55-A5246NR, C55-A5249, C55-A5281, C55-A5282, C55-A5285, C55-A5302, C55-A5384, C55D-A5240NR, C55D-A5380, C55Dt-A5250, C55t-A5218, C55t-A5222, C55t-A5287, C70-A-120, C75-A-10T, C75D-A7286, C850-1DZ, C850-1G6, C850-1K7, C850-1MH, C850-1MJ, C850-1P6, C850-1PM, C850D-12Q, C855-21U, C855-22N, C855-23Z, C855-244, C855-25T, C855-285, C855-28J, C855-2FG, C855-2G2, C855-2HC, C855-2M1, C855D-S5203, C855D-S5238, C855-S5107, C855-S5118, C855-S5122, C855-S5194, C855-S5236, C855-S5630, C855-SP5266KM, C870-1E8, C870-1H1, C870-1JL, C875D-S7120, C875D-S7225, L50T-AST2NX1, L55-A5278, L55-A5284NR, L55D-A5252, L55D-A5349, L55Dt-A5253, L55Dt-A5253NR, L55t-A5290, L75D-A7268NR, L75D-A7280, L75D-A7283, L75D-A7288, L830-14J, L830-14M, L830-16E, L830-16G, L850-1T0, L850-1T5, L850-1T7, L850-1V2, L850-1VV, L850D-13F, L855-171, L855-175, L855-176, L855-180, L855D-SP5169KM, L855-S5121, L855-S5157, L855-S5162, L855-S5163, L855-S5187, L870-17K, L870-196, L875-13C, P75-A7200, P845t-110, P855-33Q, P870-32P, P875-32Q, S55-A5239, S55-A5255, S55-A5274, S55-A5294, S75-A7221, S75-A7270, S75D-A7272, S75D-A7346, U940/K002, Z930-17G , Toshiba Satellite Pro L830-15M, L830-17T, L850-1Z8 , Toshiba Tecra R940-04K, R940-06U, R940-0CR, R940-1NR, R940-1PK, R940-SMBGX1, R940-SP4260KL, R940-ST2N01, R950-04R, R950-0CQ, R950-0CU, R950-0F0, R950-18R, R950-1C1, R950-1HJ, R950-1JE, R950-1M2, R950-1NP, R950-1P5, R950-1PM, R950-1PT, R950-1QL, R950-1QV, R950-1QW, R950-1RT, R950-SP3255KL
Scroll to top
