BT.com
Wishlist
Hypertec 4GB PC310600 240-pin 1333 MHz DIMM Memory Module
Delivery
Standard Due date unavailable
Hypertec - DDR3 - 4 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered - ECC
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Unbuffered
HP NL797AA
HP Workstation z200, z400, z800; HPE ProLiant ML110 G6, ML110 G6 Base, ML110 G6 Entry, ML110 G6 Performance, ML110 G6 Special Server; Workstation z600
4 GB
Upgrade Type
System specific
HP NL797AA
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
HP Workstation z200, z400, z800 , HPE ProLiant ML110 G6, ML110 G6 Base, ML110 G6 Entry, ML110 G6 Performance, ML110 G6 Special Server , HPE Workstation z600
Scroll to top
