BT.com
Wishlist
Hypertec 4GB 1333MHZ DIMM Memory Module
Hypertec 4GB 1333MHZ DIMM Memory...
£30.57
£30.57
Add to wishlist
Delivery
Standard Due date unavailable
4GB DDR3 1333MHz desktop memory module from from Hyperam brand. PC3-10600 DDR3 RAM memory with 240 pins and CAS latency of CL9 (1.5). Unbuffered non-ECC memory upgrade designed for mainstream computer systems.
This DDR3 memory from Hypertec is backed by Lifetime manufacturers warranty.
Also suitable for use in dual channel setup, if purchased and installed in pairs.
Hypertec - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz ( PC3-10600 )
Unbuffered
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Non-ECC
Unbuffered
Chips Organization
512 x 8
Compatible Slots
1 x memory - DIMM 240-pin
£30.57
Save on this ideal PC Build kit!
Save £10.63
£49.74
Scroll to top
