BT.com
Wishlist
Hypertec 2GB SODIMM 204-pin DDR3 Memory Module
Delivery
Standard Due date unavailable
Hypertec - DDR3 - 2 GB - SO-DIMM 204-pin - 1333 MHz / PC3-10600 - unbuffered - non-ECC - for HP 45X; EliteBook 25XX, 27XX, 84XX, 85XX, 87XX; Envy DV6, DV7; Mini 100; Pavilion dv6, dv7
RAM memory
2 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Unbuffered
HP AT912AA
HP 3115, 420, 425, 450, 455, 620, 625, 630, 635; EliteBook 2170, 25XX, 27XX, 84XX, 85XX, 87XX; Envy DV6, DV7; Mini 100, 5103; Mobile Thin Client 4320; Pavilion dv6, dv7; ProBook 43XX, 44XX, 45XX, 47XX, 53XX, 6360, 64XX, 65XX
2 GB
Upgrade Type
System specific
HP AT912AA
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Unbuffered
HP 3115m, 420, 425, 450, 455, 620, 625, 630, 635 , HP EliteBook 2170p, 2540p, 2560p, 2570p, 2760p, 8460p, 8460w, 8470p, 8470w, 8560p, 8560w, 8570w, 8740w, 8760w, 8770w , HP Envy dv6-7200ea, dv6-7200sa, dv6-7201eg, dv6-7202eg, dv6-7202ss, dv6-7203es, DV6-7210US, dv6-7214nr, dv6-7214tx, dv6-7215nr, DV6-7220US, dv6-7222nr, dv6-7223nr, DV6-7227NR, dv6-7227sa, DV6-7228NR, dv6-7229nr, dv6-7240sg, dv6-7250ca, dv6-7251eo, dv6-7252eo, dv6-7254eo, dv6-7267cl, dv6-7276ez, dv6-7280la, dv6-7280sf, dv6-7290sf, dv6-7300ea, dv6-7300sa, dv6-7302eo, dv6-7370sf, dv7-7201eg, dv7-7202eg, dv7-7202ss, dv7-7203ea, dv7-7205tx, dv7-7212nr, dv7-7215sg, DV7-7230US, DV7-7240US, DV7-7243NR, DV7-7250US, dv7-7252eo, DV7-7259NR, dv7-7270ca, dv7-7290eb, dv7-7292eo, dv7-7299ef, dv7-7299sf , HP Mini 100e, 5103 , HP Mobile Thin Client 4320t , HP Pavilion dv6-2137el, dv6-3008et, dv6-3019wm, dv6-3025et, dv6-3035et, dv6-3101et, dv6-3102et, dv6-3104et, dv6-3105et, dv6-3107et, dv6-3112st, dv6-3113et, dv6-3120et, dv6-3320et, dv6-3340et, dv6-6186nr, dv6-6b31eo, dv6-6b48nr, dv6-6c11sz, dv6-6c82sl, dv6-7000sy, dv6-7001em, dv6-7002ed, dv6-7003ax, dv6-7003sm, dv6-7003sp, dv6-7003ss, dv6-7004es, dv6-7004ss, dv6-7006ed, dv6-7009ss, dv6-7010eo, dv6-7010ss, dv6-7010us, dv6-7011eo, dv6-7013cl, dv6-7014nr, dv6-7020sg, dv6-7020us, dv6-7024eo, dv6-7024nr, dv6-7028tx, dv6-7029tx, dv6-7029wm, dv6-7030eo, dv6-7030sz, dv6-7030tx, dv6-7031tx, dv6-7040sb, dv6-7041tx, dv6-7050ca, dv6-7050eb, dv6-7050ez, dv6-7050sb, dv6-7050sw, dv6-7051sa, dv6-7053ea, dv6-7054sa, dv6-7055sa, dv6-7060sf, dv6-7061sa, dv6-7062sf, dv6-7063sa, dv6-7070el, dv6-7070sf, dv6-7070sw, dv6-7080eb, dv6-7082eg, dv6-7084la, dv6-7086la, dv6-7090ef, dv6-7090el, dv6-7090sf, dv6-7099eo, dv6-7115nr, dv7-3169wm, dv7-4069wm, dv7-4197cl, dv7-6102er , HP ProBook 4320s, 4330s, 4420s, 4425s, 4430s, 4525s, 4530s, 4535s, 4720s, 4730s, 5320m, 5330m, 6360b, 6450b, 6455b, 6460b, 6465b, 6470b, 6550b, 6555b, 6560b, 6565b, 6570b
Scroll to top
