BT.com
Wishlist
Hypertec 2GB DDR3 PC3-10600 1333Mhz Memory Module
Delivery
Standard Due date unavailable
Hypertec provides PC enhancement solutions that enable you to get maximum performance and comfort from your IT equipment, with minimum fuss.
From Matched Memory and Storage to peripherals; DVD Duplication Units to Ergonomic Workstation Equipment, Laptop Luggage and Security Products, Hypertec provides a complete solution to your needs.
Hypertec has spent over 20 years as a leading figure in the IT industry and working with the top resellers, so you can have confidence that we know what we're doing.
Hyperam - DDR3 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Unbuffered
2 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Non-ECC
Unbuffered
Chips Organization
128 x 8
Scroll to top
