BT.com
Wishlist
Hypertec 1GB PC2-4200 64X8 200 SODIMM Memory Module
Delivery
Standard Due date unavailable
Hypertec provides PC enhancement solutions that enable you to get maximum performance and comfort from your IT equipment, with minimum fuss.
From Matched Memory and Storage to peripherals; DVD Duplication Units to Ergonomic Workstation Equipment, Laptop Luggage and Security Products, Hypertec provides a complete solution to your needs.
Hypertec has spent over 20 years as a leading figure in the IT industry and working with the top resellers, so you can have confidence that we know what we're doing.
Hypertec - DDR2 - 1 GB - SO-DIMM 200-pin
RAM memory
1 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
533 MHz ( PC2-4200 )
Unbuffered
1 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
SO-DIMM 200-pin
Speed
Non-ECC
Unbuffered
Chips Organization
64 x 8
Compatible Slots
1 x memory - SO-DIMM 200-pin
Scroll to top
