BT.com
Wishlist
Hypertec 16GB DIMM 240-pin DDR3 Memory Module
Delivery
Standard Due date unavailable
A Hewlett Packard equivalent 16GB Quad rank Registered DIMM (PC3-8500R) from Hypertec.
Hypertec - DDR3 - 16 GB - DIMM 240-pin
RAM memory
16 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1066 MHz (PC3-8500)
Quad rank, registered
HP 500666-B21
HPE ProLiant BL2x220c G7, BL490c G7, BL620C G7, BL680c G7, DL360 G7, DL370 G6, DL380 G6, DL380 G7, SL160s G6; StorageWorks Network Storage Blade X1800sb G2; StorageWorks Network Storage Gateway X3400 G2, X3800 G2, X3800sb G2; StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2
16 GB
Upgrade Type
System specific
HP 500666-B21
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
1066 MHz (PC3-8500)
ECC
Compatible Slots
1 x memory - DIMM 240-pin
HPE ProLiant BL280c G6, BL2x220c G6, BL2x220c G6 Server A, BL2x220c G6 Server B, BL2x220c G7, BL460c G6, BL460c G7, BL490c G6, BL490c G7, BL620C G7, BL680c G7, DL160 G6, DL160 G6 Special Server, DL160se G6, DL165 G7, DL165 G7 Special Server, DL180 G6, DL180 G6 Special Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL370 G6 Special Server, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL980 G7, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML330 G6 Performance, ML330 G6 Special Server, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL160s G6, SL160z G6, SL170z G6, SL2x170z G6, SL390s G7, WS460c G6 Workstation Blade , HPE StorageWorks Network Storage Blade X1800sb G2 , HPE StorageWorks Network Storage Gateway X3400 G2, X3800 G2, X3800sb G2 , HPE StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2
Scroll to top
