BT.com
Wishlist
Huawei P Smart 5.6" 13MP 3GB 32GB Android - Black
Huawei P Smart 5.6" 13MP 3GB 32GB...
£211.28
More than 50 in stock
£211.28
Add to wishlist
Delivery
Standard 1-3 working days
WIDER VIEW, COMFORTABLE GRIP
The HUAWEI FullView Display features a striking 5.65-inch 2.5D glass screen that reflects vivid, true-to-life colours. The wider screen does not mean a larger body though, the thin, lightweight HUAWEI P smart fits easily in the palm of your hand.
SMART SPLIT SCREEN
The Smart Split Screen lets you run two apps side by side at the touch of a button. So when you get an important email or message while streaming TV or a movie on your HUAWEI P smart, you don't need to pause the fun.
DUAL CAMERAS, ONE AMAZING SHOT
High-spec 13MP + 2MP Dual Cameras mean top quality images at the tap of the screen. The large aperture lenses let in more light for rich, detailed, true-to-life photographs, while the Dual Camera enables perfect shallow depth-of-field bokeh shots.
HANDS-FREE SELFIE
It's never been easier to capture the moment. The HUAWEI P smart's gesture-shot function lets you take selfies and groufies with a simple wave of your hand.
Huawei P Smart - black - 4G HSPA+ - 32 GB - GSM - smartphone
Smartphone 4G
Display
LCD display - 2160 x 1080 pixels - colour - 5.65" - 428 ppi - TFT
Front-facing camera, dual rear-facing camera, digital player
Hisilicon Kirin 659 2.36 GHz (8-core) - 64-bit
32 GB - RAM 3 GB + microSDXC slot - up to 256 GB
Operating System
Android 8.0 Oreo with HUAWEI Emotion UI 8.0
Rear Camera
13 Megapixel focus: automatic
Second Rear Camera
2 Megapixel
Front Camera
8 Megapixel f/2.0
Service Provider
Not specified
SIM Card Type
Nano SIM
SIM Card Slot Qty
Single-SIM
Wireless Interface
Wi-Fi, NFC, Bluetooth
Security Devices
Fingerprint reader
Messaging Services
SMS, MMS
72.05 mm x 7.45 mm x 150.1 mm
143 g
SAR
0.99 W/kg (body) / 1.27 W/kg (head)
Smartphone
Touch
Integrated Components
Front-facing camera, voice recorder, navigation, dual rear-facing camera, digital player
72.05 mm
7.45 mm
150.1 mm
143 g
Body Colour
SAR Value
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 8.0 Oreo
User Interface
Navigation
GPS, A-GPS, GLONASS
SIM Card Type
Nano SIM
SIM Card Slot Qty
Single-SIM
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Supported Social Networks and Blogs
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE
2G Band
GSM 850/900/1800/1900
4G LTE Band
Band 1, Band 3, Band 7, Band 8, Band 20
4G LTE Frequency
FDD 2100, FDD 1800+, FDD 2600, FDD 900, FDD 800 DD
Wireless Interface
IEEE 802.11b/g/n, NFC, Bluetooth 4.2
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Ambient light sensor, proximity sensor, digital compass, gravity sensor
Security Devices
Fingerprint reader
Android Enterprise Recommended
Additional Features
Dual noise reduction microphones, Huawei Share, Split Screen
Hisilicon Kirin 659
Clock Speed
2.36 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
3 GB
Internal Memory Capacity
32 GB
Supported Flash Memory Cards
microSDXC - up to 256 GB
Front Camera
Sensor Resolution
8 Megapixel
Lens Aperture
F/2.0
Special Effects
Smart beauty
Rear Camera
Sensor Resolution
13 Megapixel
Focus Adjustment
Automatic
Special Effects
Depth of field, Bokeh effect, Smart beauty
Light Source
LED light
Second Rear Camera
Sensor Resolution
2 Megapixel
Display
LCD display - colour
TFT
Diagonal Size
5.65"
Display Resolution
2160 x 1080 pixels
Display Format
Full HD+
Pixel Density
428 ppi
2.5D Glass, FullView Display
Connector Type
Micro-USB , Headset jack - mini-phone 3.5mm
Lithium polymer
3000 mAh
USB cable, power adapter, SIM card removal tool, screen protector
Scroll to top
