BT.com
Wishlist
HPE Ultrium Non Custom Labeled Data Cartridge LTO Ultrium x 20 - 800GB - storage media
HPE Ultrium Non Custom Labeled Data...
£714.68
£714.68
Add to wishlist
Delivery
Standard 1-3 working days
With HPE Non-custom Labeled LTO Ultrium media, you no longer have to label your own cartridges, saving you time and the risk of retrieval errors. Barcode sequences are unique to each batch ordered – no codes are repeated. HPE rigorously tests its precision-engineered, high-resolution barcode labels using software unique to the HPE Automation Group to evaluate and warrant the performance of its labels in demanding, split-second datacenter environments. These labels are professionally applied in a clean environment to ensuring 100% readability accurate storage. Non-Custom Labeled cartridges ensure 100% label readability and can be ordered online, in packs of 20, using a fast and simple process. For those customer who value the added security that RFID adds, customers have the option to integrate it into each label at minimal cost. The RFID tag is embedded into the back of the non-custom label and offers tracking, audit and security advantages for those with IT asset tracking systems.
HPE Ultrium Non-Custom Labeled Data Cartridge - LTO Ultrium x 20 - 800 GB - storage media
Storage media - LTO Ultrium
Tape Cartridge
Ultrium 4
Media Included Qty
20
Green
Native Capacity
800 GB
Compressed Capacity
1.6 TB
Tape Length
820 m
Cartridge Labeling
Labeled
Metal Particle (MP)
HPE MSL2024, MSL4048; 1/8 G2 Tape Autoloader; LTO-4 Ultrium; StorageWorks MSL2024, MSL4048, MSL6030, MSL6060, MSL8096, SAS Rack-Mount Kit, Ultrium 1840; StorageWorks Enterprise Modular Library E-Series; StorageWorks Ultrium 1840; StoreEver Ultrium 1840
LTO Ultrium
Tape Cartridge
Ultrium 4
Media Included Qty
20
Cartridge Labeling
Labeled
Green
Media
Native Capacity
800 GB
Compressed Capacity
1.6 TB
Tape Length
820 m
Archival Life
30 years
Metal Particle (MP)
10 °C
45 °C
20 - 80%
Min Storage Temperature
16 °C
Max Storage Temperature
32 °C
HPE MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL4048 Ultrium 1760 , HPE 1/8 G2 Tape Autoloader Ultrium 1760 , HPE LTO-4 Ultrium 1760 SAS Drive Upgrade Kit, 1760 SCSI Drive Upgrade Kit , HPE StorageWorks MSL2024 Ultrium 1840, MSL4048 Ultrium 1840, MSL6030 Ultrium 1840, MSL6060 Ultrium 1840, MSL8096 Ultrium 1840, SAS Rack-Mount Kit, Ultrium 1840 Drive Upgrade Kit , HPE StorageWorks Enterprise Modular Library E-Series , HPE StorageWorks Ultrium 1840, 1840 Array Module, 1840 FC Drive Kit , HPE StoreEver Ultrium 1840 Drive Upgrade Kit
Scroll to top
