BT.com
Wishlist
HPE StoreVirtual 3200 4-port 16Gb FC LFF Storage
HPE StoreVirtual 3200 4-port 16Gb...
£7,423.83
£7,423.83
Add to wishlist
Delivery
Standard Due date unavailable
Does your small-to-medium business need affordable storage that's easy to manage, keeps your business up and running, and scales as your business needs grow? The HPE StoreVirtual 3000 Storage is an advanced storage architecture designed with simplicity in mind to offer a highly virtualized backend and a single storage capacity pool for superior efficiency. It offers a single screen to manage the platform via an intuitive GUI with a common look and feel with other Hewlett Packard Enterprise user experiences. It delivers an affordable, granular building block approach with an entry-level unit that scales when you need it. Such flexible scaling capabilities give you investment protection and extend ROI in a world where throw-away mentality is still common. This hardware platform runs the StoreVirtual operating system providing unique scalability, resiliency, and management capabilities to deliver a cost-effective, shared storage system for a wide range of SMB customers.
HPE StoreVirtual 3200 LFF - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
288 TB
8Gb Fibre Channel, 16Gb Fibre Channel
Maximum LUNs
2
0 (installed) / 12 (max)
Supported Drives
SAS-3
Storage Controller
2 x RAID (SAS 12Gb/s) - RAID 5, 6, 10
Hard Drive
No HDD
Microsoft Windows Server 2012, VMware ESXi 5.x, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2012 with Hyper-V, Ubuntu 12.04 LTS Server Edition, VMware ESXi 6.0
AC 120/230 V - 50/60 Hz
Power Redundancy
48.3 cm x 59.7 cm x 8.8 cm
26.3 kg
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
12
Supported Drives
SAS-3
Storage
288 TB
HDD Array External Interface
Maximum LUNs
2
2 x
RAM
Installed Size
16 GB
Storage Controller
2 x RAID
Interface Type
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Cache / Buffer Size (Max)
2 GB
RAID Level
RAID 5, RAID 6, RAID 10
Hard Drive
No HDD
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" SFF
4 x 8Gb Fibre Channel / 16Gb Fibre Channel - SFP+ , 1 x management , 1 x management - 9 pin Micro-USB Type B , 1 x management - RJ-45 , 4 x USB , 1 x Ethernet 1000
BSMI CNS 13438 Class A, EN 61000-3-2, EN 61000-3-3, UL 60950, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, RoHS, CAN/CSA C22.2 No. 60950-1, China RoHS, AS/NZS CISPR22:2006 Class A, VCCI - V-3/2014.04, ICES-003 issue 5 Class A, EN 55022, EN 55024, FCC CFR47 Part 15 B Class A
Rack mounting kit, 2 power cords
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
48.3 cm
59.7 cm
8.8 cm
26.3 kg
Limited warranty - parts - 3 years
10 °C
35 °C
10 - 90%
Sound Emission
67 dB
Scroll to top
