BT.com
Wishlist
HPE StorageWorks RDX320 External Removable Disk Backup
Delivery
Standard Due date unavailable
The HP RDX Removable Disk Backup System delivers an easy-to-use, affordable and rugged data protection solution for workstations and servers. Backups are simple and pain-free with drag and drop file access. Protect your entire system with the "hands-free" HP RDX Continuous Data Protection Software. Reduce cost of ownership with long lasting removable disk cartridges and a forward and backward compatible docking station that does not require a costly upgrade for future, higher capacity cartridges. Portable, durable and rugged removable disk cartridges simply and securely store your backups off site for complete data protection and peace of mind.
HPE RDX Removable Disk Backup System - RDX drive - USB 2.0 - external - with 320 GB Cartridge
RDX drive - external
USB 2.0
10.98 cm x 17.75 cm x 5.18 cm
540 g
Storage Removable
RDX
Media Type
RDX
Data Transfer Rate
30 MBps (external) / 480 MBps (internal)
(50/60 Hz)
Microsoft Certification
Compatible with Windows 7
Bundled with
320 GB Cartridge
Workstation xw4600; ProLiant DL165 G7, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385 G7, DL580 G7, DL585 G5, DL585 G7, MicroServer, ML110 G6, ML330 G6, ML350 G6, ML370 G6; StorageWorks Network Storage System X1400, X1400 8TB, X1600, X1600 24, X1600 3TB, X1600 7.5TB, X1800; Workstation xw8600
USB 2.0
10.98 cm
17.75 cm
5.18 cm
540 g
Bundled with
320 GB Cartridge
Storage Removable
RDX
Media Type
RDX
Data Transfer Rate
Average Seek / Access Time
15 ms
1 x USB 2.0 - 4 pin USB Type B
Media Included Qty
1
1 x USB cable
MTBF
550,000 hours
VCCI, C-Tick, EN 60950, IEC 60950, UL 60950, CISPR 22, FCC
(50/60 Hz)
6.6 Watt
Software Included
Drivers & Utilities, HP RDX Continuous Data Protection Software
5 °C
45 °C
20 - 80% (non-condensing)
HP Workstation xw4600 , HPE ProLiant DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL160 G5p Special Server, DL160 G6 Special Server, DL160se G6, DL165 G6, DL165 G7, DL165 G7 Special Server, DL180 G6 Special Server, DL320 G4 SAS VPN Server, DL320 G4 SATA VPN Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Package Cluster, DL380 G7, DL380 G7 Base, DL380 G7 Efficiency, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G5 Carrier-Grade, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G5 Performance, DL585 G6, DL585 G6 Base, DL585 G6 Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G6, DL785 G6 Base, DL785 G6 Performance, MicroServer, ML110 G6, ML110 G6 Base, ML110 G6 Entry, ML110 G6 Performance, ML110 G6 Special Server, ML150 G5 Special Server, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML330 G6 Performance, ML330 G6 Special Server, ML350 G6 Entry, ML350 G6 Performance, ML350 G6 Special Server, ML370 G6 Base, ML370 G6 Entry, ML370 G6 Special Server , HPE StorageWorks Network Storage Gateway X3400 , HPE StorageWorks Network Storage System X1400, X1400 2TB SATA Model, X1400 4TB SATA Model, X1400 8TB SATA Model, X1600, X1600 12TB SATA Model, X1600 24TB SATA Model, X1600 292GB SAS Model, X1600 3TB SAS Model, X1600 5.4TB SAS Model, X1600 6TB SATA Model, X1600 7.5TB SAS Model, X1800, X1800 2.4TB SAS Model, X1800 292GB SAS Model, X1800 3.6TB SAS Model, X1800 6TB SATA Model , HPE Workstation xw8600
Scroll to top
