Click to visit BT.com
BT.com
Wishlist
HPE Storageworks FC2142SR 4GB PCI
Quicklinx: 4LNRWS00
Mfr#: A8002A
The HP PCIe 4Gb FC Host Bus Adapters (HBAs) support customers using HP ProLiant servers with PCIe I/O slots running a broad range of operating systems. These Fibre Channel HBAs are second generation products that support this new higher speed I/O bus architecture and provide customers the ability to use it to connect to their HP storage arrays.
HPE StorageWorks FC2142SR - host bus adapter
Host bus adapter
Plug-in card
Interface (Bus) Type
PCI Express
Bus Voltage
3.3 V
Ports
4Gb Fibre Channel
16.8 cm x 6.4 cm
Cabling Type
Fibre optic
4Gb Fibre Channel (SW)
Data Transfer Rate
4.24 Gbps
Linux, Microsoft Windows 2000, Microsoft Windows Server 2003
3 years warranty
ProLiant DL120 G6, DL120 G7, DL165 G7, DL320 G6, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385 G7, DL580 G5, DL580 G7, DL585 G7, DL785 G6, DL980 G7, SL160s G6; StorageWorks SN6000C 16, SN6000C 32; StorageWorks Modular Smart Array P2000 G3; StorageWorks Network Storage Gateway X3400 G2, X3800 G2
Host bus adapter
Plug-in card
PCI Express
Bus Voltage
3.3 V
Ports
4Gb Fibre Channel
Wired
Cabling Type
Fibre optic
Fibre Channel
FC-Tape
Data Transfer Rate
4.24 Gbps
Auto-negotiation
1 x 4Gb Fibre Channel - LC
Compatible Slots
1 x PCI Express
16.8 cm
6.4 cm
Limited warranty - 3 years
45 °C
5 - 95%
HPE ProLiant DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G5, DL160 G6, DL160 G6 Special Server, DL160se G6, DL165 G5 Special Server, DL165 G6, DL165 G7, DL165 G7 Base, DL165 G7 Performance, DL165 G7 Special Server, DL170h G6, DL180 G5 Special Server, DL180 G6, DL180 G6 Special Server, DL185 G5 Special Server, DL320 G5p, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G5, DL385 G5 Base, DL385 G5 Entry, DL385 G5 Performance, DL385 G5p Base, DL385 G5p High Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G5 Highly Serviceable Tower, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G6, DL585 G6 Base, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G5, DL785 G6, DL785 G6 Base, DL785 G6 Performance, DL980 G7, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL160s G6, SL160z G6, SL170z G6, SL2x170z G6 , HPE StorageWorks MSL4048 Ultrium 1840, MSL8096 Ultrium 1840, SN6000C 16-ports Active Fabric Switch, SN6000C 32-ports Active Fabric Switch , HPE StorageWorks Modular Smart Array P2000 G3 FC Dual Controller LFF Array , HPE StorageWorks Network Storage Gateway X3400 G2, X3800 G2
