BT.com
Wishlist
HPE SPS-DIMM 2GB PC3-10600 CL9 128Mx8 dPC
HPE SPS-DIMM 2GB PC3-10600 CL9...
£64.80
£64.80
Add to wishlist
Delivery
Standard Due date unavailable
HPE 2GB PC3-10600 2GB DDR3 1333MHz memory module2GB DDR3, 240-pin DIMM, 1333MHz, Unbuffered
Internal memory: 2 GB
Internal memory type: DDR3
Memory clock speed: 1333 MHz
Component for: PC/server
Memory form factor: 240-pin DIMM
CAS latency: 9
Module configuration: 128M x 8
HP - DDR3 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Unbuffered
HP 505B
2 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
Non-ECC
Unbuffered
Chips Organization
128 x 8
Compatible Slots
1 x memory - DIMM 240-pin
HP 505B
£64.80
Save on this ideal PC Build kit!
Save £8.43
£84.02
Scroll to top
