BT.com
Wishlist
HPE SN3000 SStarter Kit Switch Managed 12x16Gb Fibre Channel SFP+ - Rack-Mountable (pack of 2)
HPE SN3000 SStarter Kit Switch...
£8,536.76
£8,536.76
Add to wishlist
Delivery
Standard Due date unavailable
To remain competitive, IT organizations must keep pace with ever-increasing workloads without a similar increase in their budgets or resources. While virtualization has provided some relief by enabling the benefits of faster deployment and consolidation, it tends to put additional stress on data center networks. The HP SN3000B 16Gb Fibre Channel Switch meets the needs of hyper-scale, private cloud storage environments by delivering market-leading 16Gb Fibre Channel technology and capabilities that support highly virtualized environments. Designed to enable maximum flexibility and investment protection, the SN3000B switch scales from 12 to 24 ports and supports 4, 8, or 16 Gb/s speeds in an efficiently designed 1U package. It also provides a simplified deployment process and a point-and-click user interface making it powerful and easy to use. It offers low-cost access to SAN technology while providing "pay-as-you-grow" scalability to meet the needs of an evolving storage environment.
HPE SN3000 - Starter Kit - switch - 12 ports - Managed - rack-mountable
Switch - 12 ports - Managed
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Rack-mountable 1U
Subtype
Fibre Channel
Ports
12 x 16Gb Fibre Channel SFP+
Performance
Fabric latency: 700 ns
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, HTTP, HTTPS, SMI-S, SSH-2
ISL support, Syslog support, firmware upgradable, back to front airflow
Power Redundancy
Optional
43.8 cm x 44.3 cm x 4.3 cm
7.82 kg
Packaged Quantity
Enclosure Type
Rack-mountable 1U
Subtype
Fibre Channel
Ports
Performance
Authentication Method
RADIUS, Secure Shell v.2 (SSH2), LDAP
1 x management (LAN) - RJ-45 , 1 x serial - RJ-45 - management , 1 x USB - Type A , 12 x 16Gb Fibre Channel - SFP+ , 12 x 16Gb Fibre Channel - SFP+ - Ports on Demand
Installed Qty
2 (max)
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
PCI-e SN1100E Dual Port 16Gb FC HBA, 4 x 16Gb Fibre Channel SFP+ Short Wave Transceiver
1 x serial cable , 4 x fibre optic cable - 5 m
Rack Mounting Kit
Included
Software Included
Brocade Advanced Zoning, Brocade Advanced Web Tools, HP SAN Network Advisor Professional, Brocade EZ Switch
43.8 cm
44.3 cm
4.3 cm
7.82 kg
10 - 85% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Scroll to top
