BT.com
Wishlist
HPE SFP (mini-GBIC) Transceiver Module - 1 Gbps
HPE SFP (mini-GBIC) Transceiver...
£72.87
£72.87
Add to wishlist
Delivery
Standard Due date unavailable
HP SFP (mini-GBIC) Transceiver Module - 1 Gbps
Form Factor: SFP
Data Rate: 1.25G
Application: 1000BASE-LX
Transmission Media: Single Mode Fiber
Reach: 10km
Cable Connector: Dual LC
Optical Output Power: -9.5dBm to -3dBm
Receiver Sensitivity: -22dBm
DOM (Digital Optical Monitoring): Unavailable
Operating Temperature: 0-70
Industrial Temperature Rated: No
HP - SFP (mini-GBIC) transceiver module - Gigabit Ethernet
SFP (mini-GBIC) transceiver module - LC
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
Gigabit Ethernet
HP 3100-8-PoE v2; HPE 10512, 12504, 1910-8G, 1910-8G-PoE+, 3100-24 V2, 3100-24-PoE v2, 3100-8 v2, 3600-24 v2, 3600-24-PoE+ v2, 3600-24-SFP v2, 3600-48-PoE+ v2, 5120-48G-PoE+, 5500-24G-PoE+-4SFP, 5500-24G-SFP, 5500-48G-4SFP, 5920AF-24XG, 7506; FlexFabric 1.92, 11908-V
Plug-in module
Wired
Cabling Type
1000Base-LX
Gigabit Ethernet
Data Transfer Rate
1 Gbps
1 x Ethernet 1000Base-LX - LC
HP 3100-8-PoE v2 EI Switch , HPE 10512 Switch Chassis, 12504 AC Switch Chassis, 1910-8G Switch, 1910-8G-PoE+ (180W) Switch, 1910-8G-PoE+ (65W) Switch, 3100-24 V2 EI Switch, 3100-24-PoE v2 EI Switch, 3100-8 v2 SI Switch, 3600-24 v2 EI Switch, 3600-24-PoE+ v2 EI Switch, 3600-24-PoE+ v2 SI Switch, 3600-24-SFP v2 EI Switch, 3600-48-PoE+ v2 SI Switch, 5120-48G-PoE+ EI Switch with 2 Interface Slots, 5500-24G-PoE+-4SFP HI Switch with 2 Interface Slots, 5500-24G-SFP HI Switch with 2 Interface Slots, 5500-48G-4SFP HI Switch with 2 interface Slots, 5920AF-24XG Switch, 7506 , HPE FlexFabric 1.92 Tbps Type D Fabric Module, 11908-V Switch Chassis
Scroll to top
