BT.com
Wishlist
HPE RDX320 BACKUP SYS DL SRV MODUL
Delivery
Standard Due date unavailable
Need a simple, inexpensive and reliable way to protect the data and systems critical to your small business? The HP RDX Removable Disk Backup System delivers an easy-to-use, affordable and rugged data protection solution for workstations and servers. Backups are simple and pain-free with drag and drop file access. Reduce cost of ownership with long lasting removable disk cartridges and a forward and backward compatible docking station that does not require a costly upgrade for future, higher capacity cartridges. The RDX Removable Disk Backup System offers fast disk-based performance. Portable, durable and rugged removable disk cartridges simply and securely store your backups off site for complete data protection and peace of mind.
HPE RDX Removable Disk Backup System DL Server Module - RDX drive - USB 2.0 - with 320 GB Cartridge
RDX drive - internal
USB 2.0
17.791 cm x 17.072 cm x 8.535 cm
1.494 kg
Storage Removable
RDX - 5.25" x 1H
Media Type
RDX - 5.25"
Data Transfer Rate
30 MBps (external) / 480 MBps (internal)
Microsoft Certification
Compatible with Windows 7
Bundled with
320 GB Cartridge
HPE ProLiant DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Special Server, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance
USB 2.0
17.791 cm
17.072 cm
8.535 cm
1.494 kg
Bundled with
320 GB Cartridge
Storage Removable
RDX - 5.25" x 1H
Media Type
RDX - 5.25"
Data Transfer Rate
Average Seek / Access Time
15 ms
1 x USB 2.0 - 4 PIN USB Type B
Compatible Bays
1 x front accessible - 5.25" x 1H
Media Included Qty
1
1 x USB cable
MTBF
550,000 hours
Plug and Play, VCCI, C-Tick, BSMI, EN 60950, RRL, IEC 60950, UL 60950, CISPR 22, FCC
6.6 Watt
Software Included
Drivers & Utilities, HP RDX Continuous Data Protection Software
5 °C
45 °C
20 - 80% (non-condensing)
Scroll to top
