BT.com
Wishlist
HPE RDX 2TB USB3.0 External Disk Backup System
HPE RDX 2TB USB3.0 External Disk...
£689.29
£689.29
Add to wishlist
Delivery
Standard Due date unavailable
Need an easy to use, affordable and reliable way to protect the data and systems critical to your small or medium business? The HP RDX Removable Disk Backup System delivers an easy-to-use, affordable and rugged data protection solution for workstations and servers. Backups are very simple with drag and drop file access. Protect your entire system with the "hands-free" HP RDX Continuous Data Protection Software which is included. Reduce cost of ownership with long lasting removable disk cartridges and a forward and backward compatible docking station that does not require a costly upgrade for future, higher capacity cartridges. The HP RDX Removable Disk Backup System offers fast disk-based performance with the ability to store 320 GB, 500 GB, 1 TB or 2 TB of data on a single removable disk cartridge at speeds of up to 360GB/hr. Portable, durable and rugged removable disk cartridges simply and securely store your backups off site for complete data protection and peace of mind.
HPE RDX Removable Disk Backup System - RDX drive - SuperSpeed USB 3.0 - with 2 TB Cartridge
RDX drive - external
SuperSpeed USB 3.0
10.98 cm x 17.75 cm x 5.18 cm
540 g
Storage Removable
RDX
Media Type
RDX
Data Transfer Rate
600 MBps (external) / 100 MBps (internal)
English / United Kingdom
1 year warranty
Bundled with
2 TB Cartridge
SuperSpeed USB 3.0
10.98 cm
17.75 cm
5.18 cm
540 g
Bundled with
2 TB Cartridge
Storage Removable
RDX
Media Type
RDX
Data Transfer Rate
Average Seek / Access Time
12 ms
1 x USB 3.0 - 9 pin USB Type B
Media Included Qty
1
1 x USB cable
MTBF
550,000 hours
TUV, VCCI, C-Tick, BSMI, EN 60950, RRL, IEC 60950, UL 60950, CISPR 22, FCC
20 Watt
Software Included
Drivers & Utilities, HP RDX Continuous Data Protection Software
Linux, Microsoft Windows
1 year warranty
Limited warranty - parts - 1 year - response time: next day
5 °C
45 °C
20 - 80% (non-condensing)
Scroll to top
