BT.com
Wishlist
HPE R1500 G4 INTL Uninterruptible Power System
HPE R1500 G4 INTL Uninterruptible...
£512.70
Hurry, only 3 left in stock!
£512.70
Add to wishlist
Delivery
Standard 1-3 working days
Looking for cost-effective power protection for your small office environments? HP Line Interactive Single Phase Uninterruptible Power System (UPS) solutions range from tower-based systems designed to safeguard tower servers and small office equipment, to rack-based systems that can protect a full rack of servers. Standard features include intuitive front panel displays for local management, hot-swappable battery modules, and HP Enhance Battery Management (EBM) that help to extend the service-life of your batteries. HP Power Protection, a power management software application that ships with each model, combined with a UPS Network Module, optional on some models, enables you to remotely monitor and manage your UPS through HP Systems Insight Manager or via a standard web browser. Backed by a 3-year limited warranty, HP's exclusive 30-day Battery Pre-Failure Warning provides notification of an impending battery failure and free battery replacement while under the warranty.
HPE R1500 G4 - UPS - 1100 Watt - 1550 VA
UPS - rack-mountable
Rack Size
1U
19.72 g
Input Voltage
AC 220/230/240/200-208 V
Power Capacity
1100 Watt / 1550 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
6 x power IEC 60320 C13
Lead Acid
Run Time (Up To)
5 min at full load
RS-232, USB
Rack mounting rails
43.8 cm x 55.4 cm x 4.3 cm
3 years warranty
ProLiant DL120 Gen9, DL160 Gen8, DL160 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360e Gen8, DL360p Gen8, DL380 Gen9, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, DL580 Gen8, DL580 Gen9, DL60 Gen9, DL80 Gen9, MicroServer Gen8, ML10, ML10 v2, ML110 Gen9, ML150 Gen9, ML310e Gen8, ML350e Gen8
Height (Rack Units)
1U
Input Voltage
Frequency Required
50/60 Hz
Input Connectors
Power Capacity
1100 Watt / 1550 VA
Output Waveform
Sinewave
Efficiency
92%
Lead Acid
Voltage Provided
36 V
Run Time (Up To)
58 min at 20% load , 17 min at half load , 8 min at 80% load , 5 min at full load
Recharge Time
24 hours
Maintenance free, sealed
Remote Management Interface
RS-232, USB
1 x USB , 1 x RS-232 - 9 pin D-Sub (DB-9)
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Rack mounting rails
USB cable - 1.83 m , Serial cable - 1.83 m
Rack Mounting Kit
Included
Equipment Protection Value
250000 US Dollars
LCD display
FCC Class B certified, UL, TUV, C-Tick, BSMI, ANSI C62.41, cUL, EN 61000-3-2, GS, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-6, UL 1778, EN 61000-3-3, EN55024, UL 60950, CISPR 22, EN 50091-2, EK, CSA C22.2 No. 107.1, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, KC, CSA C22.2 No. 107.3, VCCI Class B, EAC, IEC 62040-1, EN 62040-1
Software Included
HP Power Protector (free download)
Limited warranty - parts and labour - 1 year , Limited warranty - 3 years
0 - 90%
Sound Emission
45 dBA
43.8 cm
55.4 cm
4.3 cm
19.72 g
Shipping Width
58 cm
Shipping Depth
78 cm
Shipping Height
15.5 cm
Shipping Weight
24.7 kg
HPE ProLiant DL120 Gen9, DL120 Gen9 Entry, DL160 Gen8, DL160 Gen8 Base, DL160 Gen8 Entry, DL160 Gen8 Performance, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL320e Gen8, DL320e Gen8 Base, DL320e Gen8 Entry, DL320e Gen8 Performance, DL320e Gen8 Special Server, DL320e Gen8 v2, DL320e Gen8 v2 Base, DL320e Gen8 v2 Entry, DL320e Gen8 v2 Performance, DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL385p Gen8 Storage Centric, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, DL580 Gen8, DL580 Gen8 Base, DL580 Gen8 High Performance, DL580 Gen9, DL580 Gen9 Base, DL580 Gen9 High Performance, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, MicroServer Gen8, MicroServer Gen8 Base, MicroServer Gen8 Entry, MicroServer Gen8 Performance, ML10, ML10 Entry, ML10 v2, ML10 v2 Base, ML10 v2 Entry, ML10 v2 Performance, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML310e Gen8, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 v2, ML350e Gen8 v2 Base, ML350e Gen8 v2 Entry
Scroll to top
