BT.com
Wishlist
HPE R110 Wireless 11n VPN WW Router
HPE R110 Wireless 11n VPN WW...
£127.92
£127.92
Add to wishlist
Delivery
Standard Due date unavailable
The HP R100 Router Series is an ideal all-in-one solution for small businesses. Part of the HP OfficeConnect portfolio, the routers delivers high-performance Internet access with both wired, wireless connectivity for remote offices and employees. Featuring the next generation HP Networking user interface with an Easy Setup Wizard, they are designed for simplicity and reliability to get your business connected quickly, while robust security features safeguard your organization. The routers feature a compact executive design for unobtrusive use in office environments.
HPE R110 WW - wireless router - 802.11a/b/g/n - desktop, wall-mountable
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
Wireless, wired
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Performance
VPN throughput: up to 30 Mbps , NAT throughput: 920 Mbps
IPSec VPN tunnels: 5 , Concurrent sessions: 5 , Virtual interfaces (VLANs): 4
MAC Address Table Size
2048 entries
Network / Transport Protocol
PPTP, L2TP, IPSec, ARP, DHCP, DDNS
Routing Protocol
RIP-1, RIP-2, IGMP, static IPv4 routing, static IPv6 routing, RIPng, MLD
Remote Management Protocol
SNMP 1, SNMP 2c, HTTPS
Encryption Algorithm
WPA, WPA2
DHCP support, NAT support, VPN support, PAT support, auto-uplink (auto MDI/MDI-X), Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, IP address filtering, firmware upgradable, MIMO technology, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), Wi-Fi Protected Setup (WPS), DHCP server, Samba support, FTP server, Multiple SSID support, MLD snooping, fanless, Stateful Packet Inspection Firewall (SPIF), Network Access Control (NAC), NTP time synchronisation, Maximum Likelihood Demodulation (MLD), Class of Service (CoS), Denial of Service (DoS)
IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, EN55022 Class B, ICES-003 Class B, EN 301.489.1, EN 301.489.17, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, FCC Part 15, UL 60950-1, EN 60950-1, EN 301.893, FCC Part 15.407, EN 60601-1-2, CAN/CSA C22.2 No. 60950-1, EN 62311, EN 300 328
1 x MIPS 700 MHz
Flash Memory
128 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 1 x 4 pin USB Type A
External power adapter
9.5 Watt
MTBF
51.54 years
21.59 cm
13.97 cm
3.81 cm
450 g
Limited warranty - advance parts replacement - 3 years - response time: next business day
5 - 95% (non-condensing)
Accessories
£4.95
£3.84
£12.08
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.64
£54.72
Scroll to top
