BT.com
Wishlist
HPE ProLiant BL cClass V Conn 8Gb 24-port Fib Chann Mod Opt Kit
HPE ProLiant BL cClass V Conn 8Gb...
£8,616.20
£8,616.20
Add to wishlist
Delivery
Standard Due date unavailable
Simplify and make your data center change-ready. The HP Virtual Connect 8Gb 24-port Fibre Channel Module for c-Class BladeSystem is a new class of blade interconnect that simplifies server connections by cleanly separating the server enclosure from the SAN. It simplifies networks by reducing cables without adding switches to manage, and it allows you to change servers or move workloads in just minutes. You can reduce costs and simplify connections to LANs and SANs, consolidate your network connections and enable administrators to add, replace and recover server resources on-the-fly. The standards-based Virtual Connect 8Gb 24-port Fibre Channel Module for c-Class BladeSystem looks like a pass-thru device to the network, yet provides all the key benefits of integrated switching including high performance 8 Gb uplinks to the SAN. The integrated design frees up rack space, reduces power and cooling requirements, and reduces cables and small form-factor pluggable transmitters.
HPE Virtual Connect 8Gb 24-Port Fibre Channel Module - switch - 24 ports - plug-in module
Switch - 24 ports
Enclosure Type
Plug-in module
Subtype
Fibre Channel
Ports
24 x 8Gb Fibre Channel
Auto-negotiation, manageable
26.8 cm x 9.3 cm x 2.8 cm
1.27 kg
1 year warranty
Bundled Services
1 year warranty
BLc3000 Enclosure; BLc3000 Single-Phase Enclosure; BLc7000 Enclosure; BLc7000 Enclosure Model X; BLc7000 Single-Phase Enclosure; BLc7000 Three-Phase Enclosure; ProLiant c3000
Switch - 24 ports
Enclosure Type
Plug-in module
Subtype
Fibre Channel
Compatible Slots
1 x Expansion Slot
Ports
Fibre Channel
FC-AL, FC-AL-2, FC-FG, FC-FLA, FC-GS, FC-GS-2, FC-GS-3, FC-PH, FC-PH-2, FC-PH-3, FC-VI
Status Indicators
Port status, link activity, link OK, module locator
16 x 8Gb Fibre Channel - backplane , 2 x 8Gb Fibre Channel - LC , 6 x SFP+
VCCI, EN55022 Class A, AS/NZ 3548 Class A, UL 60950-1, EN 60950-1, WEEE, FCC Part 15 A, MIC Class A
26.8 cm
9.3 cm
2.8 cm
1.27 kg
Limited warranty - parts and labour - 1 year - on-site
10 °C
35 °C
10 - 90%
HPE BLc3000 Enclosure , HPE BLc3000 Single-Phase Enclosure , HPE BLc7000 Enclosure , HPE BLc7000 Enclosure Model X , HPE BLc7000 Single-Phase Enclosure , HPE BLc7000 Three-Phase Enclosure , HPE ProLiant c3000
Scroll to top
