BT.com
Wishlist
HPE procurve switch vl 20port Gig-T+4 SFP module
HPE procurve switch vl 20port...
£935.44
£935.44
Add to wishlist
Delivery
Standard Due date unavailable
The HP vl 20p Gig-T+ 4P SFP module switch provides 20 ports of 10/100/100-T and 4 ports of SFT for use in the Switch 4200vl series.
HPE vl 20p Gig-T+ 4P SFP module switch - expansion module
Expansion module
Plug-in module
Ports
Gigabit Ethernet x 20
20.3 cm x 22.8 cm x 4.5 cm
0.69 kg
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Auxiliary Ports
4 x SFP (mini-GBIC)
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
HPE 4208-96 vl Switch
Expansion module
Plug-in module
Ports
Wired
Cabling Type
Auxiliary Ports
4 x SFP (mini-GBIC)
Data Transfer Rate
1 Gbps
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
Expansion Slots
4 (total) / 4 (free) x SFP
20 x 1000Base-T - RJ-45
Compatible Slots
1 x Expansion Slot
20.3 cm
22.8 cm
4.5 cm
0.69 kg
Accessories
£5.16
£3.90
£12.61
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.01
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£57.07
Scroll to top
