BT.com
Wishlist
HPE procurve switch chassis 4204vl
£1,086.84
£1,086.84
Add to wishlist
Delivery
Standard Due date unavailable
The HP 4200 vl Switch Series provides cost-effective Layer 2 modular switching for enterprise edge deployments. This flexible modular switch supports 10/100, Gigabit Ethernet and 10GbE connectivity and basic IP routing with up to 16 static routes. An optional redundant power supply can be added for uninterrupted power. The HP 4200 vl Switch Series can be seamlessly managed with the optional HP Intelligent Management Center (IMC) Software Platform.
HPE 4204 vl Switch - switch - Managed - rack-mountable
Switch - Managed
Enclosure Type
Rack-mountable 3U
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c
Routing, VLAN support, manageable
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
AC 120/230 V ( 50/60 Hz )
Power Redundancy
44.2 cm x 38.9 cm x 13.3 cm
10.8 kg
Switch - Managed
Enclosure Type
Rack-mountable - 3U
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1 x Motorola MPC8245 : 330 MHz
RAM
64 MB - SDRAM
Flash Memory
24 MB Flash
1 x serial (RS-232) - DB-9 - management
Expansion Slots
4 (total) / 4 (free) x Expansion Slot
Installed Modules Qty (Max)
0 (installed) / 4 (max)
Internal power supply
Power Redundancy
630 Watt
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 60950, EN 61000-3-2, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, EN 61000-3-3, EN55024, CSA 22.2 No. 950, UL 60950
44.2 cm
38.9 cm
13.3 cm
10.8 kg
Service & Support Details
Limited warranty - lifetime
15 - 95%
Other bundles
£1,086.84
Save on TP Link Smart Plug
Save £2.00
£1,110.81
Scroll to top
