BT.com
Wishlist
HPE ProCurve 6120G/XG Blade Switch
£660.48
£660.48
Add to wishlist
Delivery
Standard Due date unavailable
The HP 6120G/XG Blade Switch for the c-Class BladeSystem enclosure provides sixteen 1 Gb downlinks, four 1 Gb copper uplinks, two 1Gb SFP uplinks along with three 10 Gb uplinks and a single 10 Gb cross-connect. A robust set of industry standard Layer 2 switching functions, QOS metering, security and High Availability features round out this extremely capable switch. The 6120G/XG is perfectly suited for datacenters in transition where a mix of 1 Gb and 10 Gb network connections are required. The 6120G/XG is one of several HP Networking data center solutions for blade enclosures that provides consistency and interoperability across existing network investments to help reduce the complexity of network management through resilient core-to-edge connectivity and automated provisioning technologies. With a variety of connection interfaces the 6120G/XG switch offers excellent investment protection, flexibility, and scalability, as well as ease of deployment and reduced operational expense.
HPE 6120G/XG Blade Switch - switch - 4 ports - Managed
Switch - 4 ports - L3 - Managed
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 + 2 x SFP + 2 x XFP + 1 x 10GBase-CX4
MAC Address Table Size
16K entries
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, SSH
Flow control, Layer 3 switching, auto-sensing per device, MDI/MDI-X switch, auto-negotiation, BOOTP support, trunking, Cisco Fast EtherChannel, VLAN support, manageable, stackable
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
(50/60 Hz)
19.3 cm x 26.8 cm x 2.8 cm
1.7 kg
Bundled Services
BLc3000 Enclosure; BLc7000 Single-Phase Enclosure; BLc7000 Three-Phase Enclosure
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
16K entries
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
Flash Memory
256 MB Flash
Status Indicators
Link activity, port duplex mode, power, link OK, test mode
4 x 1000Base-T - RJ-45 , 1 x 10GBase-CX4 , 1 x USB - management , 2 x SFP (mini-GBIC) , 2 x XFP
Installed Modules Qty (Max)
0 (installed) / 4 (max)
Internal power supply
(50/60 Hz)
FCC Class A certified, CSA, CISPR 22 Class A, CISPR 24, cUL, EN 60950, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, IEC950, NOM, UL 1950, VCCI-I
Software Included
Drivers & Utilities
19.3 cm
26.8 cm
2.8 cm
1.7 kg
Limited warranty - lifetime
10 °C
35 °C
5 - 95%
HPE BLc3000 Enclosure , HPE BLc7000 Single-Phase Enclosure w/2 Power Supplies and 4 Fans w/8 Insight Control Environment Trial Licenses, w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE BLc7000 Three-Phase Enclosure w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses
Scroll to top
