BT.com
Wishlist
HPE PROCURVE 10GBE X2-SC SR OPTIC
£1,176.98
£1,176.98
Add to wishlist
Delivery
Standard Due date unavailable
An X2 form-factor transceiver that supports the 10-Gigabit SR standard, providing 10-Gigabit connectivity up to 300 meters on multimode fiber.
HPE - X2 transceiver module - 10 GigE
X2 transceiver module - SC/UPC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10 GigE
Max Transfer Distance
300 m
3.6 cm x 8.8 cm x 1.1 cm
160 g
Aruba 5406 zl, Switch 5400zl 4p 10-GbE X2 Module; HP Switch fl 1-Port 10-GbE X2 Interface Module, Switch fl 2-Port 10 GbE X2 Interface Module; HPE 10GbE Media Flex Module, 6410-6XG cl Switch, Switch 2900-24G, Switch 2900-48G, Switch yl 10-GbE 2P CX4 + 2P X2 Module
Plug-in module
Wired
Cabling Type
10GBase-SR
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
IEEE 802.3ae
1 x Ethernet 10GBase-SR - SC/UPC multi-mode x 2
Compatible Slots
1 x X2
3.6 cm
8.8 cm
1.1 cm
160 g
70 °C
0 - 95%
Aruba 5406 zl, Switch 5400zl 4p 10-GbE X2 Module , HP Switch fl 1-Port 10-GbE X2 Interface Module, Switch fl 2-Port 10 GbE X2 Interface Module , HPE 10GbE Media Flex Module, 6410-6XG cl Switch, Switch 2900-24G, Switch 2900-48G, Switch yl 10-GbE 2P CX4 + 2P X2 Module
Scroll to top
