BT.com
Wishlist
HPE PROCURVE 10GBE X2-SC LR OPTIC
£2,579.36
£2,579.36
Add to wishlist
Delivery
Standard Due date unavailable
An X2 form-factor transceiver that supports the 10-Gigabit LR standard, providing 10-Gigabit connectivity up to 10 km on single-mode fiber.
HPE - X2 transceiver module - 10 GigE
X2 transceiver module - SC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 GigE
Max Transfer Distance
10 km
8.8 cm x 3.6 cm x 1.1 cm
70 g
Aruba 5406 zl, Switch 5400zl 4p 10-GbE X2 Module; HP Switch fl 1-Port 10-GbE X2 Interface Module; HPE 6410-6XG cl Switch, Switch yl 10-GbE 2P CX4 + 2P X2 Module
Plug-in module
Wired
Cabling Type
10GBase-LR
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex capability
IEEE 802.3ae
1 x Ethernet 10GBase-LR - SC single-mode x 2
Compatible Slots
1 x X2
8.8 cm
3.6 cm
1.1 cm
70 g
15 - 95%
Aruba 5406 zl, Switch 5400zl 4p 10-GbE X2 Module , HP Switch fl 1-Port 10-GbE X2 Interface Module , HPE 6410-6XG cl Switch, Switch yl 10-GbE 2P CX4 + 2P X2 Module
Scroll to top
