BT.com
Wishlist
HPE ProCurve 10-GbE SFP+ SR Transceiver
HPE ProCurve 10-GbE SFP+ SR...
£306.22
More than 50 in stock
£306.22
Add to wishlist
Delivery
Standard 1-3 working days
A 10-Gigabit transceiver in SFP+ form-factor that supports the 10-Gigabit SR standard, providing 10-Gigabit connectivity up to 300 m on multimode fiber.
HPE - SFP+ transceiver module - 10 Gigabit Ethernet
SFP+ transceiver module - LC/UPC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10 Gigabit Ethernet
Max Transfer Distance
300 m
1.4 cm x 5.6 cm x 1.2 cm
20 g
Aruba 2930F 24G, 2930F 48G, 5406; HPE 6120XG, 6600-24G-4XG, 6600-48G-4XG; Modular Smart Array P2000 G3; ProLiant DL360p Gen8
Plug-in module
Wired
Cabling Type
10GBase-SR
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
IEEE 802.3ae
1 x Ethernet 10GBase-SR - LC/UPC multi-mode x 2
Compatible Slots
1 x SFP+
1.4 cm
5.6 cm
1.2 cm
20 g
70 °C
Aruba 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl , HPE 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch , HPE Modular Smart Array P2000 G3 10GbE iSCSI Dual Controller SFF Array System, P2000 G3 iSCSI Dual Controller SFF Bundle , HPE ProLiant DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance
Scroll to top
