BT.com
Wishlist
HPE Premier Flex LC/LC OM4 2f 1m Cbl
HPE Premier Flex LC/LC OM4 2f 1m...
£90.90
  • Length: 1m
£90.90
Add to wishlist
Delivery
Standard Due date unavailable
HP PremierFlex cables are the addition to the HP fiber optic cable family, offering significantly better bend performance and signal-transmission integrity than existing OM3 and OM2 technologies. Uses bendable fiber technology reduced downtime, troubleshooting, and operation expense OM3+ (3000 MHz-km), multi-mode completely compatible with all OM2 and OM3 installations.
HPE PremierFlex - network cable - 1 m
Network cable - OM4
Fibre optic
Length
1 m
Connector
2 x LC multi-mode - male
Connector (Second End)
Aruba 2920, 2930F 24, 2930F 48, 5406; HP 3100; HPE 12504, 1810, 3600, 5500, 8/20, 8/24, 8Gb, MSL2024, MSL4048, SAN Switch 8/80, SN8000B 32; 1/8 G2 Tape Autoloader; Enterprise Virtual Array P6350; Modular Smart Array 1040, 2040, 2040 10, P2000 G3; ProLiant DL360e Gen8; StoreFabric 8/24 8Gb
Network Cable Type
Network cable - OM4
Fibre optic
Fibre Qty
2
Length
1 m
Connector
Aruba 2920-24G, 2920-24G-PoE+, 2920-48G, 2920-48G-PoE+, 2930F 24G 4SFP, 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP, 2930F 24G PoE+ 4SFP+, 2930F 48G 4SFP, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP, 2930F 48G PoE+ 4SFP+, 5406 zl , HP 3100-8-PoE v2 EI Switch , HPE 12504 AC Switch Chassis, 1810-24 v2, 1810-8G v2 Switch, 1910-8G Switch, 3100-24 V2 EI Switch, 3100-24-PoE v2 EI Switch, 3100-8 v2 SI Switch, 32-port 16Gb/s Director Blade, 32-port 8Gb/s Director Blade, 3600-24 v2 EI Switch, 3600-24-PoE+ v2 EI Switch, 3600-24-PoE+ v2 SI Switch, 3600-24-SFP v2 EI Switch, 3600-48-PoE+ v2 SI Switch, 48-port 16Gb/s Director Blade, 5120-48G-PoE+ EI Switch with 2 Interface Slots, 5500-24G-SFP HI Switch with 2 Interface Slots, 5500-48G-4SFP HI Switch with 2 interface Slots, 8/20q Fibre Channel Switch, 8/24 Base (16) Full Fabric Ports Enabled SAN Switch, 8/8 (8) Full Fabric Ports Enabled SAN Switch, 8/8 Base (0) e-port SAN Switch, 8Gb Simple SAN Connection Kit, MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL4048 Ultrium 1760, SAN Director 64-port 8Gb Fibre Channel Blade, SAN Switch 8/80 Power Pack+, SN3000B 16Gb 24-port/24-port Active Fibre Channel Switch, SN6000B 16Gb 48-port/24-port Active Fibre Channel Switch, SN8000B 32-port 8Gb/s Director Blade, SN8000B 48-port 8Gb/s Director Blade , HPE 1/8 G2 Tape Autoloader Ultrium 1760 , HPE Enterprise Virtual Array P6350 FC SFF Combo Field Kit , HPE Modular Smart Array 1040 Dual Controller LFF Storage, 1040 Dual Controller SFF Bundle, 1040 Dual Controller SFF Storage, 2040 10Gb iSCSI Dual Controller SFF Bundle, 2040 Dual Controller SFF Bundle, 2040 FC Dual Controller SFF Bundle, 2040 SAS Dual Controller LFF Storage, 2040 SAS Dual Controller SFF Bundle, P2000 G3 10GbE iSCSI Dual Controller SFF Array System, P2000 G3 iSCSI Dual Controller SFF Bundle , HPE ProLiant DL360e Gen8, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server , HPE StoreFabric 8/24 8Gb Bundled Fibre Channel Switch
Scroll to top
