BT.com
Wishlist
HPE Performance Hard Drive 6TB hot-swap 3.5" LFF SATA 6Gb/s 7200 rpm with HP SmartDrive Carrier
HPE Performance Hard Drive 6TB...
£439.35
£439.35
Add to wishlist
Delivery
Standard Due date unavailable
Do you have non mission-critical applications that require economical high capacity and reliability hard disk drives? HPE Server SATA Hard Drives are built for reliability and larger capacity needs for today's non mission-critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE Server SATA Hard Drives are available in both 3.5-inch Large Form Factor (LFF) and 2.5-inch Small Form Factor (SFF) and ship with a standard one-year warranty. All Hewlett Packard Enterprise hard drives pass a rigorous qualification process, which certify that every drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE Server SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
HPE Performance - hard drive - 6 TB - SATA 6Gb/s
Hard drive - hot-swap
6 TB
3.5" LFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
Advanced format 512e
105.8 mm x 170 mm x 26.8 mm
1 year warranty
Bundled with
HP SmartDrive carrier
ProLiant DL180 Gen9 (3.5"), DL180 Gen9 Base (3.5"), DL180 Gen9 Entry (3.5"), DL180 Gen9 Storage (3.5"), DL20 Gen9 (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), DL80 Gen9 (3.5"), DL80 Gen9 Entry (3.5"), ML30 Gen9 (3.5"), ML30 Gen9 Base (3.5"), ML30 Gen9 Performance (3.5"); StoreEasy 1650
6 TB
3.5" LFF
SATA 6Gb/s
Bytes per Sector
512
105.8 mm
170 mm
26.8 mm
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
7.6 ms (average) / 15 ms (max)
Track-to-Track Seek Time
0.25 ms
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" LFF
Limited warranty - 1 year
10 °C
35 °C
HPE ProLiant DL180 Gen9 (3.5"), DL180 Gen9 Base (3.5"), DL180 Gen9 Entry (3.5"), DL180 Gen9 Storage (3.5"), DL20 Gen9 (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), DL80 Gen9 (3.5"), DL80 Gen9 Entry (3.5"), ML30 Gen9 (3.5"), ML30 Gen9 Base (3.5"), ML30 Gen9 Performance (3.5") , HPE StoreEasy 1650
Scroll to top
