BT.com
Wishlist
HPE P410 512MB Flash Backed Cache
Delivery
Standard Due date unavailable
The HP Smart Array P410 is HP's PCI Express 2.0 (PCIe) Serial Attached SCSI (SAS) RAID controller. The low profile, half height card has 8 ports and utilizes DDR2-800 memory. The P410 is ideal for RAID 0/1, 1 0, 5 0 and can be upgraded with the 512MB battery-backed write cache (BBWC) module and Smart Array Advanced via license key for RAID 6 &, 6 0.
HPE Smart Array P410/512MB FBWC - storage controller (RAID) - SATA 1.5Gb/s / SAS - PCIe 2.0 x8
Storage controller (RAID) - plug-in card - low profile
Bus Type
PCIe 2.0 x8
SATA 1.5Gb/s / SAS
Data Transfer Rate
300 MBps
Buffer Size
512 MB
Supported Devices
Hard drive, disk array (RAID)
Max Storage Devices Qty
64
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
3.2 cm x 27.9 cm x 19.4 cm
1.09 kg
ProLiant DL120 G7, DL160 G6, DL165 G7, DL180 G6, DL320 G6, DL370 G6, DL380 G7, DL385 G7, DL580 G7, DL585 G7, ML110 G7, ML150 G6, ML330 G6, ML350 G6, SL165s G7, SL165z G7
Host Bus
PCIe 2.0 x8
Storage Controller
SATA 1.5Gb/s / SAS
Data Transfer Rate
300 MBps
Buffer Size
512 MB
Supported Devices
64
RAID Level
2 x SATA 1.5Gb/s / SAS - 32 pin 4i MultiLane SAS (SFF-8484) (internal)
Compatible Slots
1 x PCI Express x8
3.2 cm
27.9 cm
19.4 cm
1.09 kg
HPE ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G6, DL160 G6 Special Server, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL165 G7 Special Server, DL180 G6, DL180 G6 Special Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL370 G6 Base, DL370 G6 High Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML150 G6, ML330 G6, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML350 G6 Special Server, SL165s G7, SL165z G7
Scroll to top
