BT.com
Wishlist
HPE OfficeConnect 1405 8G v3 Switch
HPE OfficeConnect 1405 8G v3...
£40.99
£40.99
Add to wishlist
Delivery
Standard Due date unavailable
The HPE OfficeConnect 1405 is a Plug and Play unmanaged Layer 2 switch, designed for small offices. The 1405 small office switches are preconfigured for fast, easy installation, with connections using low-cost Ethernet copper cabling. They support administration-friendly features, such as auto-negotiation and automatic cable type detection (MDI/MDIX), and are FCC Class B certified and approved for both business and home office locations. They have energy-saving features, such as energy-efficient Ethernet (EEE) and idle-port power down. They are fanless for quiet and "green" operation, and are designed for high reliability, long life, low power consumption, and low total cost of ownership.
HPE OfficeConnect 1405 8G v3 - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Switching capacity: 16 Gbps , Throughput: 11.8 Mpps , Latency (100 Mbps): 3 µs , Latency (1000Base-T): 2.6 µs
MAC Address Table Size
8192 entries
Jumbo Frame Support
9216 bytes
Flow control, full duplex capability, Layer 2 switching, auto-uplink (auto MDI/MDI-X), half duplex mode, Quality of Service (QoS), fanless, Energy Efficient Ethernet, Class of Service (CoS), DiffServ Code Point (DSCP) support, 1.5MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
15.49 cm x 9.14 cm x 3.56 cm
230 g
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
8192 entries
Jumbo Frame Support
9216 bytes
8 x 1000Base-T - RJ-45
Internal power supply
4.5 Watt
Plug and Play, UL 60950, EN55022 Class B, ICES-003 Class B, RoHS, IEC 60950-1, EN 60950-1, WEEE, CAN/CSA C22.2 No. 60950-1-03, AS/NZS CISPR 22 Class B, FCC Part 15 Class B
15.49 cm
9.14 cm
3.56 cm
230 g
Limited warranty - 3 years
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Scroll to top
