BT.com
Wishlist
HPE OfficeConnect 1405 5G v3 Switch
HPE OfficeConnect 1405 5G v3...
£30.24
More than 50 in stock
£30.24
Add to wishlist
Delivery
Standard 3-5 working days
1405 series switch is Plug-and-Play unmanaged fixed-port layer 2 switches designed for small offices. The switch is preconfigured for fast, easy installation, with connections using low-cost Ethernet copper cabling. It supports administration-friendly features such as auto-negotiation and automatic cable type detection (MDI/MDIX). It is fan less for quiet and "green" operation, and designed for high reliability, long life, low power consumption, and low total cost of ownership.
HPE OfficeConnect 1405 5G v3 - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Switching capacity: 10 Gbps , Throughput: 7.4 Mpps , Latency (100 Mbps): 3 µs , Latency (1000Base-T): 2.6 µs
MAC Address Table Size
2048 entries
Jumbo Frame Support
9216 bytes
Flow control, full duplex capability, Layer 2 switching, auto-uplink (auto MDI/MDI-X), half duplex mode, Quality of Service (QoS), fanless, Energy Efficient Ethernet, 1MB packet buffer, Class of Service (CoS), DiffServ Code Point (DSCP) support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
11.43 cm x 9.14 cm x 3.56 cm
180 g
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
2048 entries
Jumbo Frame Support
9216 bytes
5 x 1000Base-T - RJ-45
Internal power supply
3 Watt
Plug and Play, UL 60950, EN55022 Class B, ICES-003 Class B, RoHS, IEC 60950-1, EN 60950-1, WEEE, CAN/CSA C22.2 No. 60950-1-03, AS/NZS CISPR 22 Class B, FCC Part 15 Class B
11.43 cm
9.14 cm
3.56 cm
180 g
Limited warranty - 3 years
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Scroll to top
