BT.com
Wishlist
HPE OfficeConnect 1405-5 Switch V2
£18.21
£18.21
Add to wishlist
Delivery
Standard Due date unavailable
The HPE 1405 Switch Series is a plug-and-play unmanaged fixed-port Layer 2 switch designed for small offices. These switches are preconfigured with connections using low-cost Ethernet copper cabling. They are Class B certified, energy efficient and quiet. They support administration-friendly features such as auto-negotiation. Designed for high reliability, long life, and low power consumption, they are ideal for businesses concerned with total cost of ownership.
HPE 1405-5 v2 Switch - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Fast Ethernet
Ports
5 x 10/100
Performance
Throughput: up to 0.7 Mpps
MAC Address Table Size
2K entries
Jumbo Frame Support
9216 bytes
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), Jumbo Frames support, fanless, Mini Jumbo Frame support, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
11.43 cm x 9.14 cm x 3.56 cm
180 g
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
5 x 10/100
Performance
2K entries
Jumbo Frame Support
9216 bytes
RAM
384 KB
Status Indicators
Port status, link activity, port transmission speed
5 x 100Base-TX - RJ-45
External power adapter
CISPR 22 Class B, UL 60950, EN55022 Class B, ICES-003 Class B, FCC Part 15, IEC 60950-1, EN 60950-1, CAN/CSA-C22.2 No. 60065-03
11.43 cm
9.14 cm
3.56 cm
180 g
Limited warranty - advance parts replacement - 3 years , Technical support - phone consulting - 3 years
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£4.95
£3.79
£11.67
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.34
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.64
£52.82
Scroll to top
