BT.com
Wishlist
HPE NC375T PCI Express Quad Port Gigabit Server Adapte
HPE NC375T PCI Express Quad Port...
£345.45
£345.45
Add to wishlist
Delivery
Standard Due date unavailable
In today's resource constrained environments, there is a predominant need to simplify infrastructure, improve manageability, optimize network performance and lower the cost of computing. The NC375T helps achieve performance scalability for consolidated server environments at an optimum price. NC375T offers four 10/100/1000T Gigabit Ethernet ports on a single card, saving valuable server I/O slots for other purposes. The NC375T is a low-profile card with both full height and half height brackets included in the kit and its x4 PCI Express interface is compatible with x4, x8, and x16 PCI slots. All HP ProLiant networking options undergo vigorous testing to ensure full compatibility with ProLiant Servers to meet exacting HP quality standards. The NC375T provides full driver support on a wide variety of ProLiant servers. The adapter ships with teaming drivers for all major operating systems, teaming utilities, and support for management tools like HP SIM and HP SmartStart software.
HPE NC375T - network adapter
Network adapter
Low profile
Interface (Bus) Type
PCI Express 2.0 x4
PCI Specification Revision
PCIe 2.0
Ports
Gigabit Ethernet x 4
16.8 cm x 6.9 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
1 x NX3031 - NetXen
RAM
128 MB
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP)
ProLiant DL120 G6, DL120 G7, DL165 G7, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385 G6, DL385 G7, DL580 G7, DL585 G7, DL980 G7, ML110 G7, ML330 G6, ML350 G6, ML370 G6, SL160s G6, SL165s G7, SL165z G6, SL165z G7, SL390s G7; StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2
Network adapter
Low profile
PCI Express 2.0 x4
PCIe 2.0
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Flow control, VLAN support, TCP/IP offloading, Quality of Service (QoS), Jumbo Frames support
Processor / Memory
1 x NX3031 - NetXen
RAM
128 MB
4 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express 2.0 x4
Low-profile bracket
FCC Class B certified, CSA, VCCI, EN55022, ICES-003, EN55024, UL 60950, CISPR 22, EMC, MIC, AS/NZS 3548, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1
16.8 cm
6.9 cm
55 °C
10 - 90%
HPE ProLiant DL120 G6, DL120 G6 Base, DL120 G6 Entry, DL120 G6 Performance, DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G6, DL160 G6 Special Server, DL160se G6, DL165 G6, DL165 G7, DL165 G7 Performance, DL165 G7 Special Server, DL180 G6, DL180 G6 Special Server, DL2x170h G6, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL370 G6 Special Server, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Efficiency, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G6 Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL4x170h G6, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G6, DL585 G6 Base, DL585 G6 Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G6, DL785 G6 Base, DL785 G6 Performance, DL980 G7, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML310 G5p, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML330 G6 Performance, ML330 G6 Special Server, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML350 G6 Special Server, ML370 G6, ML370 G6 Base, ML370 G6 Entry, ML370 G6 Special Server, SL160s G6, SL160z G6, SL165s G7, SL165z G6, SL165z G7, SL170z G6, SL2x170z G6, SL390s G7 , HPE StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2
Accessories
£4.95
£3.84
£11.43
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.18
£51.79
Scroll to top
