BT.com
Wishlist
HPE NC365T 4-PORT ETHERNET SVR ADP
£327.02
Hurry, only 3 left in stock!
£327.02
Add to wishlist
Delivery
Standard 1-3 working days
HP NC365T 4-port Ethernet Server Adapter
Are you looking for higher port density at a competitive price in your Gigabit Ethernet environment? The HPE NC365T 4-port Ethernet Server Adapter is a four lane (x4) PCI Express (PCIe) high performing single-chip, low-power quad port adapter that offers the highest port density among all HPE ProLiant Networking Options. Four ports on a single adapter are ideal for: I/O slot constrained servers, virtualization and security, server consolidation, and increased network segmentation.
Virtual Machine Device Queues (VMDq) helps to improve network I/O throughput by offloading the sorting burden from the VMM (Virtual Machine Manager) to the network controller. It helps meet the demands of consolidated virtual workloads by helping the server meet demands of multiple Virtual Machines.
It also supports TCP checksum, Large Send and Receive offload capability, Message Signal Interrupt Extension (MSI-X), IEEE 1588, Receive Side Scaling (RSS), VLAN tagging, 9.5 KB jumbo frames and IPv6.
High Performance with Low Power Consumption
The HPE NC365T 4-port Ethernet Server Adapter is a four lane (x4) PCI Express (PCIe) high performing single-chip, low-power quad port adapter that offers the highest port density among all HPE ProLiant networking options.
The HPE NC365T 4-port Ethernet Server Adapter supports Virtual Machine Device Queues (VMDq) to improve network I/O throughput by offloading the sorting burden from the VMM (Virtual Machine Manager) to the network controller.
The HPE NC365T 4-port Ethernet Server Adapter supports TCP checksum, Large Send and Receive offload capability, Message Signal Interrupt Extension (MSI-X), IEEE 1588, Receive Side Scaling (RSS), VLAN tagging, 9.5 KB jumbo frames and IPv6.
Intel® is a trademark of Intel Corporation in the U.S. and other countries.
Technical features
Network processor
Intel® 82580
Data rate
10/100/1000 Mbps, Half- and full-duplex
Bus type
PCI Express v2.0
Form factor
PCIe Card
5.0W @ 3.3v maximum
Server type supported
ProLiant servers
IEEE compliance
802.3, 802.3u, 802.3ab, 802.3x, 802.3ad, 802.1p, 802.1q, 802.3z, 1588
Compatible operating systems
Microsoft Windows Server 2008
Microsoft Windows Server 2003 R2 SP2
Red Hat Enterprise Linux (RHEL)
SLES 10, 11
VMware ESX 4.0 Update 1
Microsoft Windows Hyper-V
Product differentiator
Quad Port Ethernet Server Adapter
Dimensions and weight
Dimensions (W x D x H)
5.72 x 24.13 x 19.05 cm
0.45 kg
HPE NC365T - network adapter
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x4
Ports
Gigabit Ethernet x 4
13.5 cm 6.9 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
ProLiant DL120 G7, DL165 G7, DL360 G7, DL360p Gen8, DL370 G6, DL380 G6, DL380 G7, DL380p Gen8, DL385 G6, DL385p Gen8, DL560 Gen8, DL980 G7, MicroServer Gen8, ML10, ML110 G7, ML310e Gen8, ML350e Gen8, ML350p Gen8, ML370 G6, SL160s G6, SL165s G7, SL230s Gen8, SL250s Gen8, SL270s Gen8, SL4545 G7
Network adapter
PCI Express 2.0 x4
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
4 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express 2.0 x4
13.5 cm
6.9 cm
HPE ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL165 G7 Performance, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Special Server, DL370 G6 Special Server, DL380 G6, DL380 G7 Base, DL380 G7 Efficiency, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385 G6 Performance, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL980 G7, MicroServer Gen8 Performance, ML10 Entry, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML310e Gen8 v2, ML330 G6 Special Server, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350e Gen8 v2 Base, ML350p Gen8, ML350p Gen8 Special Server, ML370 G6 Special Server, SL160s G6, SL165s G7, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 2U Left Half Width Tray, SL250s Gen8 2U PCIe Gen3 Left Tray, SL250s Gen8 2U PCIe Gen3 Right Tray, SL250s Gen8 2U Right Half Width Tray, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Right Half Width Tray, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL270s Gen8 SE 4U Left Tray, SL270s Gen8 SE 4U Right Tray, SL4545 G7
Accessories
£5.11
£3.88
£12.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.92
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£56.55
Scroll to top
