BT.com
Wishlist
HPE MSR20-40 Router
HPE MSR20-40 Router
£1,182.14
HPE MSR20-40 Router
£1,182.14
Add to wishlist
Delivery
Standard Due date unavailable
The HP MSR20 router series is a component of the HP FlexBranch solution, which is part of the HP FlexNetwork architecture. It features a modular design that delivers unmatched flexibility for small branch offices and small to medium-sized businesses while reducing complexity, simplifying management, and increasing control. MSR20 series routers provide a full-featured, resilient routing platform, including IPv6 and MPLS, up to 180 Kpps forwarding capacity, and 100 Mbps encryption. These products offer lasting investment protection, and help reduce capital and operating expenses.
HPE MSR20-40 - router - rack-mountable
Router
Enclosure Type
Rack-mountable - modular - 1U
WAN Ports Qty
2
Ethernet, Fast Ethernet
Network / Transport Protocol
TCP/IP, L2TP, RSVP, NTP, PPPoE
Routing Protocol
OSPF, BGP-4, IS-IS, RIP-1, RIP-2, IGMPv2, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, GRE, OSPFv3, Multiprotocol BGP, MSDP, static IPv4 routing, static IPv6 routing, RIPng
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, Telnet, SNMP 3, HTTP, FTP, SSH
Firewall protection, DHCP support, NAT support, VPN support, NAPT support, ARP support, MPLS support, IGMP snooping, Syslog support, port mirroring, IPv6 support, Weighted Fair Queuing (WFQ), Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
36 cm x 28.7 cm x 4.4 cm
5.4 kg
Router
Enclosure Type
Wired
Routing Protocol
Encryption Algorithm
MD5, SSL, TLS
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, ICES-003 Class B, FCC Part 68, RoHS, UL 60950-1, IEC 60950-1, CSA C22.2 No. 60950-1-03, WEEE, CSA C22.2 No. 60950-1, EN 60825-1
1 x 400 MHz
RAM
256 MB DDR SDRAM
Flash Memory
256 MB (max)
WAN: 2 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x , USB: 1 x
Expansion Slots
1 (total) / 1 (free) x CompactFlash , 4 (total) / 4 (free) x Smart Interface Card (SIC)
Installed Modules Qty (Max)
0 (installed) / 4 (max)
Internal power supply
36 cm
28.7 cm
4.4 cm
5.4 kg
5 - 90%
Scroll to top
