BT.com
Wishlist
HPE Modular Smart Array 2042 SAN Dual Controller LFF Storage
HPE Modular Smart Array 2042 SAN...
£6,613.22
£6,613.22
Add to wishlist
Delivery
Standard Due date unavailable
Would you like to accelerate your performance-hungry applications with flash storage? The HPE MSA 2042 SAN Storage offers an entry level storage platform with built-in hybrid flash for application acceleration and high-performance. It is ideal for performance-hungry applications and includes 800 GB of Solid State Drive (SSD) capacity. The all-inclusive set and forget software suite includes built-in, real-time data tiering that dynamically moves frequently used data to flash and less used data to lower-cost media tiers. This suite also includes 512 snapshots out-of-the-box for instant recovery, and remote replication for affordable application availability. The software delivers management tools that are ideal for IT generalists and server administrators. The MSA 2042 allows for flexible growth now and into the future. Data-in-place upgrades reduce data migration and drive investments. Start small and scale as needed with any combination of SSD, SAS or midline SAS drives.
HPE Modular Smart Array 2042 SAN Dual Controller LFF Storage - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
800 GB
Max Supported Capacity
96 TB
8Gb Fibre Channel, iSCSI (1 GbE), iSCSI (10 GbE), 16Gb Fibre Channel
Maximum LUNs
512
2 (installed) / 12 (max)
Supported Drives
SAS-3
Storage Controller
2 x RAID (SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 50
Hard Drive
2 x 400 GB SSD Mixed-Use
HP-UX, Red Hat Linux, Apple MacOS X, SuSE Linux Enterprise Server, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012
Power Redundancy
Optional
44.7 cm x 57.2 cm x 8.9 cm
18.4 kg
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
2
Supported Devices / Modules Qty
12
Supported Drives
SAS-3
Storage
800 GB
96 TB
HDD Array External Interface
Maximum LUNs
512
Storage Controller
2 x RAID
Interface Type
SAS 6Gb/s
Data Transfer Rate
600 MBps
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 50
Hard Drive
SSD
2 x 400 GB
Mixed-Use
Expansion Bays
12 (total) / 10 (free) - 3.5" LFF
8 x 8Gb Fibre Channel / 16Gb Fibre Channel / Ethernet 10Gb / Ethernet 1000 - SFP+ , 2 x USB - mini-USB Type A , 2 x management - RJ-45 , 2 x
Software Included
HPE Advanced Data Services Suite
VCCI, EN55022, GS, ICES-003, CCC, FCC Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, RoHS, CAN/CSA C22.2 No. 60950-1-03, KN24, KN22 Class A, China RoHS, AS/NZS CISPR 22, CNS 13438, EN61000-3-2, EN61000-3-3, EN 55024
0 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Optional
44.7 cm
57.2 cm
8.9 cm
18.4 kg
5 °C
10 - 90% (non-condensing)
Sound Emission
55 dBA
Scroll to top
