BT.com
Wishlist
HPE Modular Smart Array 2040 SAN Dual Controller SFF Bundle
HPE Modular Smart Array 2040 SAN...
£4,819.04
£4,819.04
Add to wishlist
Delivery
Standard Due date unavailable
Changing storage needs for server customers now requires greater levels of performance and functionality at a lower cost of ownership. The next generation HPE MSA 2040 Storage arrays raises the bar & uniquely addresses HPE ProLiant customers' shared storage and data protection needs, reduces TCO while dramatically increasing performance using technologies such as Solid State Drives, Snap and Volume copy, Replication and SEDs. The MSA 2040 Storage arrays are positioned to provide an excellent value for customers needing increasing performance to support initiatives such as consolidation and virtualization. The MSA 2040 delivers this performance by leveraging new controller architecture with a new processor, four ports with 4GB cache per controller & using drive technologies such as SSDs. The MSA 2040 Storage ships standard with 64 Snapshots and Volume Copy enabled for increased data protection and allow replication with optional Remote Snap software between arrays (FC or iSCSI only).
HPE Modular Smart Array 2040 SAN Dual Controller SFF Bundle - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
3.6 TB
Max Supported Capacity
43 TB
8Gb Fibre Channel, iSCSI (1 GbE), iSCSI (10 GbE), 16Gb Fibre Channel
Maximum LUNs
512
6 (installed) / 24 (max)
Supported Drives
SAS-3
Storage Controller
2 x RAID (SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 50
Hard Drive
6 x 600 GB HDD
HP-UX, Red Hat Linux, SuSE Linux Enterprise Server, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012
AC 120/230 V - 50/60 Hz
Power Redundancy
Manufacturer Selling Program
HP Top Value Lite
44.7 cm x 49.5 cm x 8.9 cm
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
6
Supported Devices / Modules Qty
24
Supported Drives
SAS-3
Storage
3.6 TB
43 TB
HDD Array External Interface
Maximum LUNs
512
Storage Controller
2 x RAID
Interface Type
SAS 6Gb/s
Data Transfer Rate
600 MBps
Cache / Buffer Size (Max)
8 GB
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 50
Hard Drive
HDD
6 x 600 GB
Expansion Bays
24 (total) / 18 (free) - 2.5" SFF
2 x SAS 6Gb/s - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088) , 2 x management , 2 x management - RJ-45 , 8 x 8Gb Fibre Channel / 16Gb Fibre Channel / Ethernet 10Gb / Ethernet 1000 - SFP+
CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, GS, EN 61000-3-3, EN55022 Class A, CCC, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, RoHS, FCC Part 15 A, EN55024 Class A, CAN/CSA C22.2 No. 60950-1-03, VCCI Class A
HP Top Value Lite
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
44.7 cm
49.5 cm
8.9 cm
Limited warranty - parts - 3 years
5 °C
10 - 90% (non-condensing)
Sound Emission
55 dBA
Scroll to top
