BT.com
Wishlist
HPE Modular Power Distribution Unit with Power Monitoring
HPE Modular Power Distribution Unit...
£1,066.64
£1,066.64
Add to wishlist
Delivery
Standard Due date unavailable
Do your administrators want flexibility in deployment of power monitoring for your data center racks? The HP Monitored Power Distribution Unit permits your administrators to monitor current draw at the rack and per PDU. The monitored vertical rack mount power distribution units, provide both single and three-phase monitored power for increased power redundancy, as well as full-rack power utility ranging from 4.9 kVA up to 22 kVA. Each PDU includes full rack models with 39 receptacles or with 78 receptacles, and half rack versions, 3 phase models with 12 C19 receptacles, and single phase models with 24 C13 and 3 C19 receptacles. HP Monitored Power Distribution Unit provides local power display. An optional PDU management module provides remote monitoring capabilities of the PDU across the network.
HPE Monitored Power Distribution Unit Half Rack Version S332 - power distribution strip
Power distribution strip - rack-mountable
11 kg
Input Wiring
3-phase WYE (star)
Output Voltage
AC 200-240 V
Input Connectors
1 x power IEC 60309
Output connectors
12 x power IEC 60320 C19
9.6 cm x 9.4 cm x 71.9 cm
UPS R/T3000 G2, R12000/3, R1500 G3, R5000, R7000, R8000/3, T1000 G3, T1500 G3, T750 G2; BLc7000 Single-Phase Enclosure; BLc7000 Three-Phase Enclosure; ProLiant DL120 G6, DL160 Gen8, DL580 G4, DL785 G5, DL785 G6; Rack
Input Voltage Range
AC 380 - 415 V
Frequency Provided
50/60 Hz
Input Wiring
3-phase WYE (star)
Frequency Required
50/60 Hz
Input Connectors
1 x power IEC 60309
Output Voltage
AC 200-240 V 50/60 Hz
Max Electric Current
32 A
Circuit Protection
Circuit breaker
9.6 cm
9.4 cm
71.9 cm
11 kg
HP UPS R/T3000 G2 Detachable Cord High Voltage, R12000/3, R1500 G3, R5000, R7000, R8000/3, T1000 G3, T1500 G3, T750 G2 , HPE BLc7000 Single-Phase Enclosure w/2 Power Supplies and 4 Fans w/8 Insight Control Environment Trial Licenses, w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE BLc7000 Three-Phase Enclosure w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE ProLiant DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL160 Gen8, DL160 Gen8 Entry, DL160 Gen8 Performance, DL580 G4 High Performance, DL785 G5, DL785 G6, DL785 G6 Base, DL785 G6 Performance , HPE Rack
Scroll to top
